Bearings for Norden Front Axle
PeaRidge180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeaRidge180 Quote  Post ReplyReply Direct Link To This Post Topic: Bearings for Norden Front Axle
    Posted: 14 Aug 2017 at 6:00pm
I need a set of hub bearings and wheel bearings for a Farmall M with a Norden front axle.  The axle serial number is 216_ , but I can't see anything after 216.  Can anyone point me in the right direction?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2017 at 6:07pm
Pull a bearing, and see if there's a timkin or other # on the race...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeaRidge180 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2017 at 9:52pm
We have taken it apart. The hub bearing had tin wrapped around the axle to make that bearing fit. The wheel bearing fit but cant find a number on the bearing for either the right or left side. Is it possible to measure the thickness of the axle as well as the width and height of the bearings and find replacements? What company would you suggest calling?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 4:55am
I imagine it can be done, that way, but it may be easier to go over to the red power or smoke stack forums, and ask the question, there.  You need some help from someone who has handled that particular problem, before...
Edited by DiyDave - 15 Aug 2017 at 4:55am
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 10:32pm
I would say they are IH wheel bearings. Most after market front ends came without hubs and used the hubs from the tractor.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeaRidge180 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 10:35pm
Okay. Thanks for the assistance.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 11:35pm
http://farmallparts.com/Front_Wheel_Bearing_Kit_HV_Super_H_M_MD_Super_M_Wide_Front_Only_W4_300_330U_350/p24326
http://www.ebay.ca/itm/WBKIH4-WHEEL-BEARING-KIT-Wide-Front-Only-for-FARMALL-H-HV-M-MD-W4-300-330-350-/172164966815?hash=item2815d4e99f:g:PdkAAMXQLw1Rzb2S
B:-)      Dnoym
PS
take these number and the old bearing with
you to a bearing place and see if they look right
(1) Inner Cone:   14138A
(1) Inner Cup:     14274
(1) Outer Cone:  1779
(1) Outer Cup:    1729
(1) Seal:              48539DA
(1) Sleeve:          48548D
(1) Felt:               43828D
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 6:12am
Can be done with measurments but you should have a micrometer  to get correct size. Napa can order going by size and I have done this but you need exact sizes.
Arcs and Sparks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcs and Sparks Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 6:34am
IF you have a good bearing and race that fits and you want to replace that with new ones then take what you have to any good bearing shop.  In Canada I use Canada Bearing or a place called Motion Bearing.  They will just measure the main points and cross reference them to available replacements.  I do it all the time and it takes less than 10 minutes.  Bearing quality really ranges these days so pay the difference and go with a brand name.  You;ll find that going this route will always be cheaper than going OEM.  You won't be paying for the expensive parts system overhead of the OEM network.  Good luck
This page was generated in 0.060 seconds.
