Trip Beam Plow Question
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Trip Beam Plow Question
    Posted: 30 Apr 2011 at 12:25pm
How tight should the main bolt that the stem pivots on be?  My stems wiggle a bit.  Thanks!
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 9:50pm
bump
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 6:46am
Just loose enough that when you pull the trip roller up by hand you should be able to pivot the moldboard back by hand. Is this a monoframe? On mine I had to disassemble the mechanism to clean it up enough so it would trip by hand. There are supposed to be washers on each side of the beam at the pivot but mine were just about completely worn away so I replaced them. Then I had to adjust the little coil trip spring pressure cause it tripped too easy. After adding a couple washers under one spring on one bottom they all four will trip nicely and only when I hit something and I still can lift the plow and trip them by hand.
Wink
I am a Russian Bot
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 9:39am
The last monoframe plow I bought there are two trip mechanisms that have a bolt put into the mechanism, I am assuming this is to keep those moldboards from tripping.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 11:57pm
Good way to eventually ruin the plow. Needs adjusting.
Wink
I am a Russian Bot
