WD45 Diesel Cylinder Head Torque
sparkyb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparkyb Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Diesel Cylinder Head Torque
    Posted: 02 Aug 2017 at 6:46pm
I have a WD 45 Diesel and was wondering if I replace the head gasket do I need to re-torque when the engine is hot?
Thanks
OrangeFever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 6:52pm
I would recommend retorque of gasket but why are you taking it apart??? Odds are you will find issues with the sleeves having sunk.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 6:24am
The bolts will already be tighter than spec when the engine is hot. It's a matter of simple expansion. If the need to be retorqued at all I would retorque the bolts after the engine has been hot, but after it cools down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparkyb Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 7:03am
I purchased the tractor about 6 months ago and I was took the motor was rebuilt. Did not notice any oil leak from head at that time (engine never really warmed up). Now that I am using it I have found that oil is leaking from the injector side of the head once the engine gets hot. Checked and no Coolant in crank case. Motor does sound good.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 7:22am
If you choose to re-torque, do it with a COLD engine.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 8:37am
If you have not removed the head off the engine I'd check if the head bolts will even hold being re-torqued first, I'll bet the bolts are bad and or the threads are too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparkyb Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 11:52am
Thanks guys, I will check torque with engine cold and go from there.
Thanks again,
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 3:45pm
The threads on those head bolts will stretch. And also your sleeves could have sunk. Both have happened to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparkyb Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 4:17pm
Thanks for the information. what did you do to fix the problem?
Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2017 at 7:24am
I sell steel fire rings that will keep sleeves from sinking.     MACK
Post Options Post Options   Thanks (1) Thanks(1)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2017 at 12:42pm
When I did my 262 I found probably half of the head bolts were pitted and not just a little. I put it back together with ARP studs and nuts. IIRC The studs cost about 2/3 of what new bolts from AGCO were.
