Will a CA Trans and axle fit on a B
JR Maley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Maley Quote  Post ReplyReply Direct Link To This Post Topic: Will a CA Trans and axle fit on a B
    Posted: 06 Apr 2011 at 9:31am
This is just an idea that I had.  I like the short narrow compact size and non-tricycleness of an Allis B, but I wish I had 4 speeds and that my pto would still run when I put the clutch in like a CA.  Has anybody on here looked into the feasability of this or tried it?
-JR
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 9:45am
The elusive BA.  I have done some research and it looks do able.  However, for it to remain the B width, you have to forgo the axle clutch that gives it the allusion of live PTO.  You might consider going with a Wide Front CA and adjust the wheels in to the narrowest setting.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 10:58am
Essentially, the only think you would need to change is the torque tube if you are using an earlier B, and the front end to make a CA if you are swapping out the Trans and Rear Axle. Might as well just go buy a CA...
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 11:44am
the only way to keep the PTO live is to use the hand clutch, if you use the foot clutch everything stops.
Here is one for sale close to me. this is more along the lines of a CA with a B wide front.
http://minneapolis.craigslist.org/csw/grd/2301481431.html
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 3:03pm
You need an english   D270
B chassis and motor, 4 speed tranny CA (almost) but B narrow rear end with hand clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 3:07pm
Allis Chalmers made it first !!!!!!!!
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 10:54pm
Have a D270 looking for a home
This page was generated in 0.107 seconds.
