ac 180 Diesel starter
AC 180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 180 Quote  Post ReplyReply Direct Link To This Post Topic: ac 180 Diesel starter
    Posted: 16 Jun 2017 at 3:11pm
looking for help on why ac 180 diesel starter is not engaging.Both battery check good-just had starter rebuilt= new selonoid.I have been chasing wires looking for bad connection found none.Took starter back to rebuilder and they adjusted Bendix depth and put a different new selonoid in case it was faulty new one.Sounds like starter gear is spinning but not engaging.Took starter out laid it on bench used jumper cables ground on starter case then touched hot ontried contact for motor selonoid s terminal Bendix jumps out then tried hot on post of starter and it turned starter motor.Any Ideas
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 7:53pm
While starter removed, look in hole and see what the teeth on ring gear look like. Tractor is 40 years old and the ring gear may be getting worn. I've never had 1 lose teeth or get worn down on 180 or 200, but have replaced some on D series tractors.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 8:50pm
Ditto on the ring gear.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 10:37pm
What brand of starter do you have?    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 180 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 6:37am
teeth look good on flywheel and starter is Delco
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 6:48am
Never seen it happen but could the thru. shaft have come loose and everything is spinning on it? Can't think what that shaft is called, but just something that came to my mind to look at.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 7:52am
Binder is bad.     MACK
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 7:55am
Bindex
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 180 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 8:47am
Bendix kicks in and out strong.Bendix is suppose to turn clockwise.Is that looking from operators seat or standing at radiator looking toward rear of tractor?I think Rebuilder has it turning wrong way.Is that possible when they said they put new brushes and fields in?
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 8:53am
Starter should be turning clockwise when you're looking at the gear end.  If you're looking at the starter from the end away from the gear it should turn counter clockwise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 9:14am
I'm not electrical but sounds possible  change direction by messing with fields and brush holder.You know starters turn opposite directions when facing opposite directions on engines.Your Bendix would free wheel in that case.Guessing it worked ok before(Bendix)?
