Gear Jumping
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: Gear Jumping
    Posted: 16 Jun 2017 at 1:09pm
I saw an ad for a decent looking D14 that ran good, but jumped out of 3rd. My question is what is actually happening that causes this. Is it a bearing or something that gets worn and causes the main shaft or gear stack to thrust back and forth popping them out of gear? An automotive trans if they jump out it usually is a detent issue in the shift rails.
I was looking at the parts breakdown of an early D17 and it looks very simple compared to an NV4500.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 1:13pm
The Dog ears on the gears get worn and won't hold the gears together
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 1:29pm
Loose brgs,too much play in gear stack(snap rings or shim washers)shift rail detent needing moved for a little deeper engagement.Lots of contributors beyond gear grinding which does what Charlie shows. See if the shift lever can be pushed deeper in gear in 3rd beyond detent.If so you may make it useable by by welding/grinding a new deeper detent notch.Beyond that,it's a lot of work/$.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 5:14pm
And naturally 3rd gear is the one that gets used the most. I rarely use any other gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 6:48pm
The funny part of this problem all it takes to keep it in gear is holding your hand against it with a little force and it stays right in
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 6:48pm
Brian,  If it was me looking at buying I would figure $1000 per gear that it jumps out of, you being a good mechanic you may get by cheeper but cost can add up fast if you fix it right.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 9:02pm
But that will wear out the shift fork.  Then it's just another part to replace while you have the tranny apart to do a proper fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 9:31am
LOL! Brian has rebuilt a Buda diesel....he's no stranger to spending money and hard work!!
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 12:05pm
See this mentioned a lot and I also have a D 14 . Dad never let gears grind. I wondered if any one has ever welded up those dogs .I used to weld some and know you can weld to pretty close the same hardness as the shifter dogs. Retired and have a lot of time to think  and some may be a bit foolish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 3:15pm
 I used to do a lot of tig welding to repair cutting surfaces in pierce dies. It takes a controlled pre-heat and post heat and the proper rod to maintain hardness without becoming brittle.
That being said, when I got my 45 and found out it jumped out of 3 rd, I bought a new gear and shifting collar. There is a lot of labor involved to have to go back and do it over, so I did it right the first time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 8:55pm
Don't forget countless 6.0/6.4 Powerstrokes and a few Duramax too.
Thanks for the explanation guys. The next bit of work is the Power Director. I've been accumulating parts over about 3 years for this problem. While I'm at it I'll have a look at the bearings in the trans too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 12:10am
yeah...but at work your spending someone elses money....
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 9:56am
Great care must be taken if using any sort of electric welding device.
NEVER weld through a bearing!!!!!
ALWAYS disconnect the charging system before welding.
