New to me All Crop SP100
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Topic: New to me All Crop SP100
    Posted: 14 Jun 2017 at 7:52am
Just bought an Sp100 this past weekend and as far as the drives and mechanics of it its kinda out of what im used to! I ve got it running and driving but the separator wont engage, the linkage moves but the coupler wont go together! Any thoughts or advice on anything on this machine is appreciated!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 9:27am
Is the coupler free to move? Maybe its froze on the shaft. Can you post a picture of the coupler? We may see something in the picture that will help.
Edited by DennisA (IL) - 14 Jun 2017 at 9:29am
Thanks & God Bless
Dennis
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 10:36am
You probably have a sheared roll pin. I had that happen at Hutch in 2015. The linage will swing free, but nothing will happen in the back. Do you have a manual? If so, it shows it on page 80 of the regular SP-100 manual.
Also, since you said it's different from what you're used to...remember the 100 is pretty different from any other color combine, as far as mechanics and general operation. You must be stopped and the clutch disengaged to engaged the separator.
If you have any other questions, don't be afraid to ask! When I walked onto the grounds at Hutch in 2015, I had never ran an All-Crop, much less a 100. Granted, I'd read through regular and Super 100 manuals, but I quickly found you learn the most by actually being around and operating the combine. Give it a little while and you'll know that machine like the back of you hand!
Edited by CrestonM - 14 Jun 2017 at 10:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 11:13am
the shear pin sounds like it could be, the linkage moves but not correctly. im familiar with the pull type all crops I have several! just never been around a 100 much. bit of a bear tp back in the barn cant see a thing! Creston you sound like the go to man when I comes to the 100! send me your email address and I will send you some pics, never had much luck posting them on here!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 1:28pm
I know what you mean about backing them! Takes two people to park them, really.
Sent you a PM with my e-mail.
Thanks
P.S.- I see in your signature now all the All-Crops you have! Sounds like you just need a early High Speed/Camel back and a Super 100 and you'll have the whole lineup!
Edited by CrestonM - 14 Jun 2017 at 1:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 11:13pm
Here are the pics! Note the home-brew power steering! Neat!
Speaking of ingenuity, I've never seen an auger swivel like this one. Has to be another farmer mod to accommodate the bin extension.
Note in the above pic- it seems the PS pump is driven off the bin unloader drive idler. Must be a double pulley?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 6:45am
Thanks Creston for posting the pics of my machine, yes that power steering is some good old farming ingenuity but makes it steer like a Cadillac. I'm keen to see how it steers with a loaded bin. Is that auger swivel factory or another farmer fix?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 8:29am
I'd appreciate it if you could get some more detailed pics of the power steering setup. I'm curious as to how the built it all.
From the factory, the auger would fold out for unloading, then for transport or storage you could either fold it straight up, or pull the hinge pin at the bottom and lay it across the top of the bin. However, with the homemade bin extension, they could no longer lay it across the bin, so the farmer must have fixed the latch system somehow so he could swivel the auger instead.
Here is how it's supposed to store when folded back. To unload then, you have to jump up and grab the bottom end of the auger, pull it down, put the hinge pin in, pull on the release chain, and carefully move it out to unload position. Then attach the 2 braces and put 2 small bolts at the bottom of the auger flange where it meets the bin.
That's not too big of a hassle, but that's why I like the Super 100's better. The auger on them is 2 pieces and splits in the middle.
Edited by CrestonM - 15 Jun 2017 at 8:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 11:36am
if its gonna be a nice weekend up here im gonna get all my all crops out for a photo shoot right from the 40 up to the 100!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 11:41am
Creston just seeing your earlier comment yes id like one of those early camel backs but scarce up here but I do know an old collector up here that has a Super 100 stowed away in his back shed in immaculate condition! Been working on him a few years to convince to sell it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 2:50pm
I've seen 4 camel backs down here. All have been "out to pasture" for decades, and one is full of bullet holes. Lol
There is one that is (to me) half decent, and I might get it one day, when I have more barn room and get a place of my own. I imagine I could have it cutting after a month or two of work.
Keep working on the guy with the Super 100! Never know when he'll finally break down and sell it! It sounds like a nice machine.
Are you coming to Hutch this year? If so, you'll see mine there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 9:47pm
Some year I'd like to get to Hutch, just a long haul from here, tough to get away with two boys under 4. I'm hopin to have the 100 ready to thresh wheat in three weeks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 9:58pm
That'll be fun!! Make sure to get pics and/or videos!
Also, some detailed pics of the power steering setup would be nice!
Here are a couple pics of my Super 100, since you can't make it to Hutch. I'm also ready to get out and cut with it. I've never ran it before, as we just got it last August.
I understand with young'uns runnin around, it would be hard to make that long of a trip. It's a bit of a stretch for me too, driving up from Oklahoma. We break it into a 2 day trip. It's about 800 miles one way.
They'll be grown up before you know it, then you can get them in on the Allis combines as well!
Edited by CrestonM - 15 Jun 2017 at 10:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 6:19pm
Did some tinkering on my 100 and the swivel looks factory cause it does have a scour clean and won't be able to lay across the bin. This swivel allows it to lay across the separator.
