Engine Oil for 2035
psheridan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote psheridan Quote  Post ReplyReply Direct Link To This Post Topic: Engine Oil for 2035
    Posted: 14 Jun 2017 at 9:35pm
What viscosity of oil should I use in my 2035
straight 40wt? 30 Wt?
Also , I suppose that since the pan has two petcocks, I would fill the pan up to the lowest petcock?.  if so , what is the highest petcock for?
I dont have a spec on the oil capacity, I do not have a owners manual  yet.
Also, I would suppose that the governer takes the same oil and to the petcock as well?
thanks for the help
Paul
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 9:57pm
    Manuals available by vendors on this site.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 9:29am
Either of those oils would probably be fine.  Would be way better than what was available when the tractor was new.  If the engine is not in new shape, 40 would probably be great.  I assume you won't be starting it on a -20 morning!  As far as the two petcocks, I've seen instructions that when running on low octane fuel, you are supposed to drain the oil down to the lower petcock and refill to the upper at some interval that's more frequent than for a full oil change due to oil dilution from the unburned fuel that makes it into the crankcase.  Like the other post said though, get a manual and read it.  Will always be something you didn't know or even think about.
Edited by DanD - 15 Jun 2017 at 9:30am
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 11:17am
from the operators manual:
Pan should be filled to upper petcock and oil level maintained between the upper and lower petcock.  They serve a similar function to the upper and lower level marks on a dipstick.
Governor should be filled to the petcock with same oil as used in the engine.
Edited by Alberta Phil - 15 Jun 2017 at 11:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote psheridan Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 6:32pm
Thank you very much for your replies
the nice thing about his website is that you most often get real experienced replies and often times opinions and comments that  you do not get from the manual.
this is more than just a manual site !
that is why I keep coming back for more
thanks
Paul
