WF
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: WF
    Posted: 27 May 2017 at 4:46pm
Has any one stuffed a 226 into a wf ?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2017 at 7:24pm
Basically, all you have to do is replace the 4" stroke crankshaft with a 4.5" WD45 crankshaft. If you use 4.125 pistons, you will end up with 240 cubic inches and, from the outside, it will look identical to the stock 201 engine.
Matt -mid-mich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt -mid-mich Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 6:01pm
I have a 226 in a wf I pull with you will need to shorten crank shaft I think was and inch and had to ream out crank pulley some and use the water pump from old engine by re drilling holes
We have 86400 seconds to everyday make every second count because we never know when it's our last
