planter markers
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: planter markers
    Posted: 22 May 2017 at 9:06am
On my 333 the right hand marker slowly works its way down when the left hand marker is down. Would it be something in the switch valve or whatever its called causing this? There's no sign of leaks from the cylinder unless its completely internal.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 3:50pm
surplus center sell a flip flop valve.  I have it on my 15ft drill.  it works great and you can even figure out how to have both markers down at the same time.
AC from the start of my families farming career till the end!
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 4:00pm
You use two way to speed it up lowering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 5:09pm
I took the markers off my 6-30 years ago...don't need them.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 9:17pm
I use my GPS.    MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 10:17pm
internal leak, most common. .pac it. Also the sequence valve could have a piece of trash or oring in it. Simple to check , pull allen plug and remove detent ball the the fittings to each marker and under each is a ball seat that can be examined , any mark on the steel ball will cause a leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 10:27am
Thanks Tim, I'll check it out. I've been using it for 2 years without the markers but it would be nice to have them working again.
