D10 TRACTION BOOSTER
Jeff K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff K Quote  Post ReplyReply Direct Link To This Post Topic: D10 TRACTION BOOSTER
    Posted: 04 Sep 2016 at 8:42pm
Guys, I have what I believe to be a simple question that I can't figure out on my own. I am hoping for some help.
I am not going to hook up my Traction Booster on my D10 Series 3 restoration. It's going to be a parade tractor so I doubt I will need it. My question is; what do I have to plug so there isn't oil spitting out where the tube that used to go to the Traction Booster comes from?
In other words, where would the tube connect to?
Thanks,
Jeff
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 4:14am
Are you referring to the line coming from the valve stack going to the TB gauge on the dash panel following the shape of the transmission, torque tube area?
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 6:25pm
Jeff,
If you are not going to run the line to the traction booster gauge, you will need to plug the outlet for the line that is located on the front side of the control valve under the control levers.  In the picture below, the line has been cut and soldered.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 9:20pm
I sell a new nonworking tb gauge for looks only. it has a fitting to connect the original line to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff K Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 3:53pm
Thanks for the pic Larry. That is exactly what I needed to know.
Jeff
This page was generated in 0.075 seconds.
