Question, Draining transmission oil on 7050 |
| Author | ||||
AC Orange 1
Topic: Question, Draining transmission oil on 7050Posted: 04 Oct 2016 at 9:57am |
I want to change the transmission oil on my 7050. When looking at the Operator's manual it states that there are two front transmission drain plugs. I only see one. I've included a picture of the page in the Operator's Manual and my tractor. My tractor does not look the same as the Operator's manual picture shows. Also, the pump screen cover plate at the rear of the transmission doesn't look the same as in the manual either (I don't have a picture of that but I can get one tonight if I need to). Thanks in advance for any advice.
7050.pdf ![]()
1937 (AC WC), 1952 (AC WD), 1957 (AC D17 SERIES 1), 1964 (AC D17 SERIES IV WITH FACTORY 3PT), 1970 (AC ONE-NINETY XT SERIES III), 1971 (AC ONE-EIGHTY)
| Sponsored Links | ||||
Tcmtech
Posted: 04 Oct 2016 at 10:07am |
There is the front plug which you have in your picture then there is a back plug below the right rear axle.
Also there is ~2 gallons of fluid in the PTO gear cavity above the rear cover plate as well that does not have a drain plug to get it out. For that I would recomend drilling a ~1/4" hole about 2" in from the rear and left side of that rear plate to drain that then drill and tap the hole to put a 1/8" or 1/4" pipe plug in it.
Posted: 04 Oct 2016 at 10:21am |
What you have is an update from a newer 7060,called a sewer pipe system. There is one drain plug underneath the transmission (above the rubber hose) that takes an 1 1/8" wrench, and one of the four 3/8" bolts at the bottom has a special flat washer on it and is the lower drain. To access the screen for cleaning you need to remove that sump and cover plate. Use good adhesive on both sides of both gaskets and let cure before refilling with oil.
AC Orange 1
Posted: 04 Oct 2016 at 11:21am |
Ok, thank you for the quick responses. I appreciate the knowledge you are willing to share.
MACK
Posted: 04 Oct 2016 at 9:55pm |
There is about 1 1/2 gal in range transmission that will not drain out. Can be sucked out through dip stick tube. MACK Tomtech, you are talking rear end not transmission.
Tcmtech
Posted: 04 Oct 2016 at 10:50pm |
Yes I know, but they share internal connections and thusly circulate the same fluid through them so if a transmission fluid change is being done then ideally all the fluids from the transmission back should be done as well. |
MACK
Posted: 05 Oct 2016 at 7:07am |
They are two separate compartments, one is filled and checked with dipstick in cab, rear end is checked at rear housing with sight glasses and filled at top of rear end housing. If they mix there is a oil transfer problem. MACK
Tcmtech
Posted: 05 Oct 2016 at 8:52am |
When i worked on ours to put a dual speed PTO in it once the main PTO shaft was pulled everything in the differential and transmission drained down to that level.
Also when refilling fluids putting fluid in the rear filler brings everything right up to where they need to be as well being there is a passage built into the casting above and to the side of the PTO shaft that connect the rear cavity to differential section. That's what I know from first hand experience. I've topped off fluids that way many times this year after blowing hoses and cylinder seals on the baler and hay conditioner plus the PTO shaft seals that dumped lot of fluid before being found. |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12337 |
Posted: 05 Oct 2016 at 9:31am |
Well from my first hand experience, I can tell you topping off one does not fill the right where it needs to be. If what you say is true, why in the heck would they have built the tractor with 2 check points and 2 fill points?
Tcmtech
Posted: 05 Oct 2016 at 11:29am |
How many other brands and models of tractors have multiple plugs or points that could be used checking various fluids?
I for one don't consider a dipstick tube a fill point. Especially one inside the cab. I mean what idiot would put a fill point for a transmission that takes 10+ gallons in the cab just under the seat where it's hard to get anything bigger a 1 gallon jug and a small funnel into without spilling all over the place? I for one do not consider that a valid fill port anymore than I consider the engine oil dipstick tube an engine oil fill port. Just because it can be done there doesn't mean it's right let alone the best. Personally I don't worry about the little stuff. I put fluid in the big port on the back and the right level shows up on the dipstick in the cab. That's good enough for me.
Tbone95
Posted: 05 Oct 2016 at 11:43am |
No clue. None of the Ford, JD, Massey Ferguson, or Allis (?) models I have personal experience with have multiple points for the same fluid.
I guess you can call some poor guy who worked for Allis many years ago an idiot if you want. My bucket pump works great for it. Set the bucket on the step, tube in the FILL POINT , pump away.
In that poor dipstick tube's defense, it is a pretty big tube. In fact, on my tractor, it's about the same size as the fill point on the back of the tractor!
Well isn't that special! ![]() I just did as the operators manual said to do. I didn't feel I was smarter than it. Edited by Tbone95 - 05 Oct 2016 at 11:44am |
Posted: 05 Oct 2016 at 11:49am |
Well, that's not how it's supposed to work. The dipstick/fill tube in the cab is from that point forward to the flywheel. It encompasses the range transmission/park lock, main transmission and Power Director clutch and the trans brake. That front compartment holds approx. 7 to 7 1/2 gallons of oil. The sight glasses on the rear end is for the differential, brakes, ring and pinion, final drives, PTO and the hydraulic system including the power steering. It holds around 17 to 18 gallons with a filter change. The two compartments are designed to be separate from each other. Not saying there isn't a problem with your tractor, but that's the way it should be...2 different compartments.
KY poorboy
Posted: 05 Oct 2016 at 6:07pm |
As Mac said, if you can fill both from one filler tube, there is a transfer problem. I had a 7060 that was transferring one year during planting season. We connected both compartments with a rubber tube just to make it through planting. But, we had to fill them through the fill tube in the cab to get the correct amount in the transmission. The rearend was over full some when the tranny was at correct level. We had no problem with the rearend a little over full, but from personal experience, if you overfill the tranny compartment, it will overheat badly. We made it fine until we could split it and fix it correctly.
Tcmtech
Posted: 06 Oct 2016 at 12:18am |
Up until three years ago we never owned any Allis anything so these quirks of design are all new to me and come off as being rather odd to be polite compared to everything else I have ever worked with in my life. On all of our other stuff everything from the flywheel back is one reservoir and most have two or more plugs or points that fluids can be checked and filled from if needed. To me that was plain and simple assumed to be common design so i never questioned that AC was different. When I drained the system to do the PTO work I just dumped all the fluid back in through rear filler port and when done it showed up on the dipstick where it was supposed to be so I had no reason to question it and have been adding fluids to it that way ever since. To be honest the more I learn about AC's designs the less and less impressed I am with them but being they are cheap tractors to pick up and do what we need most of the time without too much hassle, Oh well, that's what I have to deal with until we find better ones like a MF 2000 series.
Tbone95
Posted: 06 Oct 2016 at 6:41am |
^^^That's not the problem. The problem is you hop on here and bluster and blast your through posts contradicting guys like Mack and Dr. Allis who either of which know more than most of the rest of us put together, as if you're the expert. Then turn around and state you've only owned Allis for 3 years and don't like their designs.
You're entitled to you opinions of Allis, and you're entitled to post about anything you want. Just show a little humility once in a while, you don't know everything. I know I certainly don't! |
Posted: 06 Oct 2016 at 7:56am |
The pluses of the two sump design is better oil level control when operating up and down slopes, and less contamination of the entire tractor if there is a problem somewhere. The engineering design of multiple magnetic drain plugs also helps in the diagnosis of a problem, where tractors that have only one or maybe two drain plugs may leave you guessing as to where the failure actually is. A NewHolland Genesis is a good example of that. One drain plug for the whole tractor.....bad idea when you have a failure of brakes or a transmission.
Tcmtech
Posted: 06 Oct 2016 at 11:10am |
I don't do humility. I do actions and experiences right or wrong. To me humility is almost as much of a waste of time as worrying about 'what if's'. Some people spend their lives excelling at both. I don't. I get crap done with what I have to work with and deal with the problems as they show themselves. Someone asked about draining the fluids so I gave reference to my experiences given what I have worked with. TIme of ownership involved is irrelevant. I've known many people who have been brand loyal their whole lives and even covering multiple generations of their family who never knew a damn thing about what they had the whole time. If something broke they paid someone else to fix it making their time of ownership totally irrelevant to their knowledge of what they had an used day in and day out. We see that in threads here every single day. Guys who have owned machines for years or decades that have never som much as opened up a inspection plate or done a simple repair before. Put fuel in, start it up and go. Change fluids as needed. That's what they have done and know. Not anything past that. ![]() What spun out from there was not my doing. I just responded to what was being asked or responded to as with this post.
Tcmtech
Posted: 06 Oct 2016 at 11:13am |
Thanks for taking the time to clarify that! ![]() Big fan of magnetic plugs too! Made and installed many mysel! |
Tbone95
Posted: 06 Oct 2016 at 11:23am |
Humility, respect, acknowledge other people have knowledge, whatever you would like me to call the general concept that you have 2 ears, 2 eyes, and one mouth, and sometimes they ought to be used with a nod to that ratio.
You first shared your experience, that was fine. When myself, Mack, and Dr. Allis told you that was wrong, you argued with it and still thought you were right. When you eventually came to realize you were in fact wrong, then it was just a stupid design from Allis that doesn't impress you. Now the good Dr. explained why in fact it is a good design, and OH, well then... Whatever. It's obvious you can't be reached. Your first paragraph in your last response to me describes yourself to a T, and now I know. |
Tcmtech
Posted: 07 Oct 2016 at 12:58am |
When did any of this happen? please quote it specifically being I do not see it even after multiple rereads of my posts. I posted what I experienced and what I came to conclude from it. That's it. Nothing else. It seems a number of people on this forum take a lot of benign comments out of their context and way too personally which that in itself is not my problem though and I see zero reason to change anything about what I say or who I say it. If I see something I find questionable I will point out why I see it that way. IF I have an experience with something i will share it for good or bad so that others can be aware of what I came across just as I did in the begining of this thread. As much as I dislike it I am more than capable of humility. The problem is the situation actually has to justify it before I am going to bother with it. Making a personal comment on what I have seen and experienced first hand and how I feel about it's not something that requires humility in my books. To me Humility is much like gratitude and respect. You can't demand it of others. You have to earn it and what I have seen of a number of peoples repeatted butt hurt whining on what I or anyone else says around this forum you most certainly do not deserve any of my humility gratitude or respect. Neither does it relate to taking any other person's comments or criticism either. Unlike a lot of people in this world I get up in the morning and put my big boy pants on and accept that not 100% of the world see thing my way nor do I see many things as others. That's life. Deal with it. I have to and I certainly don't get all demanding over it either. ![]() In my views anyone can criticize anything about me or anything I own or do. That's what freedom of speech in this country is about. I have zero issue with it being not all comments or criticism are negative. To be honest, you or anyone else could criticize any of my favorite machines and I would take no issue with it let alone get butt hurt over it. What I would do is likely agree, being I probably already know about whatever design limitation there is you or anyone else can find, and I probably have or know of some solutions to fix the problem! ![]() As far as me learning things, if it's something I can see to be of value I take it to heart. If not, it's just someone else's opinion and of little concern or consequence to me. Now as for who says what, Well, Dr Allis explains things in rational unbiased terms relating to the how and way of the design and not much else. He does not get butt hurt over my frustrations or comments of what I find less than ideal by my views and thus gets humble thank you from me almost every time. ![]() Unfortunately there are a number of other here who could do far better tame to learn from that and not take every single comment that is not dripping with royal orange worship as a insult or direct attack on one's soul. There just frigging tractors design by human beings. BTW. If you really want to know how good a component or system's design is just look at a John Deere and see if they have ever copied it then claimed ti to be there own and advertised the heck out of it! If not then it probably wasn't so great of design concept of invention!
Tbone95
Posted: 07 Oct 2016 at 6:59am |
Basically right through here, combined with the experiences of you on the B oil pressure thread. Earning Respect: You first encounter or meet a stranger. How do you treat them? Like a piece of dirt because they have to earn your respect starting from 0? Or is there a base level of respect for people, and they can add to it or diminish it from there? Just a question.
Tcmtech
Posted: 07 Oct 2016 at 10:59am |
I thought so and see now.
Clearly I'm dealing with another pompous fool here who can't read proper context from basic sentences that likes to get upset and judgemental over his perceived take on what is not actually there or implied. ![]() So given that, yes ,I will deal with you just as I do with such idiots in public. Let them have their say and I walk away. If being such a illiterate moron that people walk away from you is your way of winning an argument, well happy winings to you. ![]() Post whatever you want about me from here to further justify your win in your mind. I won't be back.
ac45dave
Posted: 07 Oct 2016 at 11:43am |
KY poorboy
Posted: 07 Oct 2016 at 2:21pm |
I was always taught that only a fool does not open their mind up to others ideas and opinions. Especially when they are proven wrong and will not admit it.
Edited by KY poorboy - 07 Oct 2016 at 2:22pm |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2880 |
Posted: 07 Oct 2016 at 8:39pm |
Tbone is no fool! Just a god ole boy. As far as Dr Allis goes what he posts is good as gospel. |
bigal121892
Posted: 07 Oct 2016 at 10:36pm |
Regardless of anything else, you may want to have your oil transfer problem fixed, because sooner or later, it will cause problems and get expensive.
Tbone95
Posted: 10 Oct 2016 at 7:02am |
Why thank you Mr. Victory! |
