Thinking ahead on the L-3
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Topic: Thinking ahead on the L-3
    Posted: 17 Dec 2016 at 7:38pm
Has anyone tried to put a bin extension on the L series(other than what it has). Like the Maurer extension. Had to make a cover to go behind the clean grain elevator, at the end of the season you can get about 10 bushels of corn and beans mixed out of that area.
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2016 at 8:25pm
Here is one that someone put a bin extension on. Looks like a homemade job.  http://www.equipmentlocator.com/photos/equip/603560-1.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2016 at 8:28pm
I seen that one, really does look neat, like it's supposed to be there
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2016 at 8:34pm
We have a Mauer on our R62 makes it a PAIN to get in and out of the grain tank. Just a FYI
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2016 at 9:49pm
I would like to put a small extension on the L3's we have but dad's afraid the clean grain slip clutch wont handle it. Sometimes you just need that extra 15-20 bushels to make a full round in good corn. The R62's with a 230-250 bushel bin is what I really want.......when that happens, I don't know.
Leon B MO
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2016 at 10:28pm
Would be nice if the stock extension had "flaps" on the sides that folded up too. Ours always spills over on the right side before it overflows on the left side.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 12:06am
like Leon, I needed just a little more room on my "G". and one day I looked at the other extension on the parts "G", and it being the same size it should work! I took that extension off and turned it upside down, and there were already holes in the framework that matched up. I just bolted it on top and nothing else was needed to mount it! it was usually enough to get me to the end of the field. but sometimes doing end rows it would get almost full to the top then the clean grain slip clutch took off! i'm sure you could fit any of the screen type extensions off other combines to fit. and they'd be cheap! it doesn't hafta fit the whole bin, if you mount it away from the sides of the lower bin, it should keep that one from over flowing out on side hills.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 11:24am
Not sure how much you want to add but how about some baler belting? can get that up to at least ten inches, maybe more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 5:52pm
I even thought about finding an old satellite dish (the screen ones) set it on top and trace the bin edge out, make a frame to fit that edge and bolt it on. I don't have to get in the bin anyway, I fixed that problem, made me a fold in door in the side of the grain tank and bolted a piece of channel at an angle that ends close to the door(like the JD's have). And I'm wanting to put a Loup system on it anyway for moisture
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 6:59pm
lets see a pic of that door
JFREED View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JFREED Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 8:02pm
Can the axles hold up to an extension?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 10:50pm
Check this out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 5:26am
Sorry Shameless, forgot how to post a picture.
//i1243.photobucket.com/albums/gg548/bakwoodsfarmbakwoodsfarm/farm20017_zps2batu4dc.jpg[/IMG][/URL][/IMG]
Edited by bakwoodsfarm - 22 Dec 2016 at 5:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 5:29am
[/IMG]
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 5:30am
finally remembered how
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 12:09am
I do not know for sure, but it appears the one that VAfarmboy posted is a Bish extension.
If anyone would have plans sitting around for older models, I bet bish would.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 11:30pm
We took the Mauer off our Deere 9550 because it was a PAIN to climb up there and fold it down every time we put it in the shed.
