D12 steering shaft |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5060 |
Topic: D12 steering shaftPosted: 07 Dec 2022 at 8:19am |
I have a D12 that needs a new steering wheel. Unfortunately, a previous owner welded the nut on the shaft. I have looked, unsuccessfully, for a new steering shaft. Suggestions?
Travis2766
Joined: 26 Aug 2015 Location: Amherst, Wi Points: 439 |
Posted: 07 Dec 2022 at 8:57am |
Break off the rest of the plastic, grind the weld off flush with the nut using an angle grinder, use a die grinder and carefully grind the root of the weld out, should leave enough of the threads to thread a new nut back on. If you don’t have a die grinder you can grind off the weld above the nut and split the nut with a cold chisel, then carefully clean up what weld is left above the threads with a grinder. Otherwise there’s a couple used shafts on eBay.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
WF owner
Posted: 09 Dec 2022 at 6:51am |
I have been checking Ebay daily. I have never seen a steering shaft for a D12. I can find them for a D14, D15 or a D17, but none for a D10 or D12. Where did you find them?
Travis2766
Posted: 09 Dec 2022 at 7:06am |
My bad, I had d14 stuck in my mind. Could you shorten one from a d14?
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 09 Dec 2022 at 8:28am |
I'd grind the nut off and take the shaft to a machine shop and have them weld a new end on it.
Charlie
Joined: 11 Sep 2009 Location: illinois Points: 88676 |
Posted: 09 Dec 2022 at 8:39am |
I have done that on a couple B... i shortened the shaft on a couple, and have cut the top 2 inches off the shaft on one and welded a stud back on.
WF owner
Posted: 09 Dec 2022 at 4:24pm |
I am wondering if the shaft os hollow (I don't think it is). If it was I could probably get a bolt with the right thread and put it in the lathe and turn it down to the ID of the shaft.
Posted: 09 Dec 2022 at 4:33pm |
the shaft is hollow on a "B" ... i did exactly what you said.
allis1221G
Joined: 10 Apr 2013 Location: Hudsonville Points: 648 |
Posted: 09 Dec 2022 at 6:46pm |
I should have a shaft. 616-334-0844
WF owner
Posted: 09 Dec 2022 at 7:18pm |
Mine is a D 12 Series 3. I believe the early ones were different. Which one do you have?
Coolharts
Joined: 03 Dec 2022 Location: Central NC Points: 21 |
Posted: 04 Apr 2023 at 12:18pm |
My D10 has the same issue, nut welded on but unlike yours, it is welded on farther down the shaft below the steering wheel opening.
Posted: 04 Apr 2023 at 12:31pm |
Jon... how did they get down below to weld ?? Easy way would be the nut on top ?
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7542 |
Posted: 04 Apr 2023 at 4:17pm |
That's a later model steering shaft with a splined end which the steering wheel sits on. Best to find a used shaft from a D15 or 17 and shorten the opposite non-splined end.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 06 Apr 2023 at 12:54am |
Doesn't the steering wheel have a spline? If so welding a bolt will not work.
