Year for allis chalmer b
LiL B Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LiL B Orange Quote  Post ReplyReply Direct Link To This Post Topic: Year for allis chalmer b
    Posted: 25 Mar 2025 at 11:59am
B 93884 is the serial number the number isn't on the chart can someone tell me the actual year and not send me the chart
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2025 at 12:26pm
the LAST tractor built in 1948 was 92xxx... and the LAST tractor built in 1949 was 102xxx..
so yours would be a 1949..
Post Options Post Options   Thanks (0) Thanks(0)   Quote LiL B Orange Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2025 at 12:56pm
Thanks I had the tractor for a couple years my grandfather passed in 2019 from cancer and my grandmother gave it to me also it doesn't want to start
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2025 at 1:09pm
after setting for a couple years you can have corrosion on the POINT ( distributor or magnito?) .......... and you can have gasoiline evaporate from the carburetor and plug up or stick the inlet needle..
pull the plugs and put 1-2 in the wire and ground to the block... crank and see if you have spark..... see if the carb has a drain plug, remove and see if gas flows easy... tap on the carb if the inlet valve seems to be STUCK closed..
