fuel in oil
R.KYLE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Topic: fuel in oil
    Posted: 30 Nov 2015 at 8:16pm
I HAVE AN HD11F. THE TRACTOR HAS AN 11000 ENGINE IN IT. IT HAS AN AMERICAN BOSH INJECTION PUMP. FUEL IS LEAKING INTO BASE OF ENGINE. ANYONE ELSE HAD THIS PROBLEM AND HOW TO FIX. THANKS.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 8:29pm
transfer pump seal is bad, leaking fuel into lubed side of pump and going back to engine?  or leaking onto the outside?
Edited by CAL(KS) - 30 Nov 2015 at 8:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 8:38pm
LEAKING INSIDE. DOES PUMP HAVE TO BE REMOVED?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2015 at 3:37pm
transfer pump bolts to outside of psb pump  i had a 7000 engine that was doing this
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2015 at 4:38pm
THIS IS NOT COVERED IN THE BOOK I HAVE BUT I DO HAVE A DIGIRAM OF PUMP. IT LOOKS LIKE THE SUPLY PUMP CAN BE TAKEN OFF WITHOUT REMOVING INJECTION PUMP FROM ENGINE AND GETTING INTO PUMP TIMING. ALSO WONDERING WHERE TO ORDER SEALS. ANY HELP THANKS.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 7:40pm
Jobbers Inc used to have some American Bosch stuff, www.jobbersinc.com
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2015 at 2:24am
Been here with an AC 45 grader.
You can take the transfer pump off without removing the injection pump.  And the seal on the transfer pump shaft ours was just a standard industrial seal.
Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2015 at 10:21am
i got my seal from injpumpED
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 4:17pm
JUST AN UPDATE. GOT A NEW PUMP FROM JOBBERSINC .COM. TRACTOR IS RUNNING AGAIN AND WORKING FINE. THANKS EVERY ONE FOR HELP.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 4:24pm
would be good idea to change the oil and filter if you hadn't.
Richard66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard66 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 8:34pm
Does anyone have any information about an American Bosh PSB6A-75y-4123A fuel pump? I’m getting fuel in my motor oil on a WD45
Edited by Richard66 - 18 Jan 2024 at 8:36pm
