|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 1978 ac 715D backhoe |
| Post Reply   | Page <12 |
| DMiller   Orange Level Access   Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34338 |  Post Options  Thanks(0)  Quote  Reply  Posted: 02 Sep 2018 at 7:19am |
   Have seen almost every ground engagement tool supplier tooth or cutting edge on every machine except Cat, can pretty well replace a lost tooth head on a shank from any distributor so long as you find a knowledgeable parts man that can recognize the types.
| Coke-in-MN   Orange Level Access   Joined: 12 Sep 2009 Location: Afton MN Points: 42033 |  Post Options  Thanks(0)  Quote  Reply  Posted: 02 Sep 2018 at 10:19am |
   I have a 12" trench bucket from a Ford I modified to fit machine and it takes a small tooth that you use a ball peen hammer to dimple side to attach to shank - on the AC bucket 32" the split pin with rubber center holds tooth to shank . Bought a couple frost teeth to use along with the standard teeth .
     Life lesson: If you’re being chased by a lion, you’re on a horse, to the left of you is a giraffe and on the right is a unicorn, what do you do? You stop drinking and get off the carousel.  | |
| Chris Dame   Bronze Level   Joined: 11 Apr 2023 Location: Grovespring Mo. Points: 8 |  Post Options  Thanks(0)  Quote  Reply  Posted: 12 Apr 2023 at 9:51am |
   Would anyone have a 1002958 valve assembly for 715D backhoe? Mine is cracked
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
