CA spider gear shims |
racin69z ![]() Bronze Level ![]() Joined: 11 Jan 2015 Location: Jackson mo Points: 43 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Nov 2015 at 9:45am |
While working on my CA, I found that the spider gears inside the differential had what I would consider excessive clearance. I did not measure with my dial indicator, and I have more of a car and truck background, so I don't know if it was OK or not.
My service manual mentions selective shims. I called Sandy Lake, and they are not available. The side gear shims are available but they do not mention the thickness. They are $90 each!! Needless to say without knowing what they are supposed to be, I will not be buying those. In the mean time, I got to thinking, man these really look like truck shims and cups. I tore a dana 44 front end I had sitting in the woods apart and the shims are almost exactly the same. The only difference is that the center hole is about .020-.050 larger. The cups are exactly the same size and the same amount of dish. The Dana cups and shims are about .010 thicker if I remember correctly. Installing the dana 44 cups and shims tightened it up quite a bit. I thought if anyone else had this problem this may help. Lynn
hillmonkey ![]() Orange Level ![]() ![]() Joined: 03 Apr 2010 Location: oville fl Points: 417 |
on truck rear ends D44s and 60s ETC. we used to cram as many shims in between the side gear and the carrier as possible. kind of a poor mans limited slip. everything was fine the next time we tore it apart. i dont think you can go to tight on a low speed rear like a tractor.
