thinking of getting duals for wd allis
keith wd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keith wd Quote  Post ReplyReply Direct Link To This Post Topic: thinking of getting duals for wd allis
    Posted: 23 Nov 2015 at 10:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote keith wd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 10:02am
Originally posted by keith wd keith wd wrote:
neigbor is got some duals for wd allis and just wondering if any input on that idea
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 10:18am
The width can be an issue with duals depending on how you use it. If it has to go through a barn door it gets tight and if you bale hay the tire can run over the win row if width isn't a problem it is a great way to add traction.
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 10:43am
Dad had a set of Duals for WD-45--even with a narrow front, worked well in spring for working ground--other than that they were off.   R. Musgrave
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 12:21pm
I have a set on one of the WD45s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote keith wd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 1:32pm
nice tractor i`ve never seen one with a single wheel with duals
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 2:24pm
I have a set that I hope on using in the spring.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 9:51pm
they are nice for workin plowed ground
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 7:23am
Here's a couple pictures of mine with duals on.
[/IMG]
[/IMG]
AC7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7040 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 7:40am
A couple pictures; one with duals on, other with duals off. To connect the duals you take out 6 of the 8 of the bolts leaving the other 2 to hold the inside tire on. The dual rim has two cutouts that allow the rim to slide over the 2 bolts that hold the inside tire on. You then reinstall the 6 bolts, this will now hold the outside tire on as well as the inside tire. Pretty neat setup. Can take more pictures if you have questions.
1953-WD45, 1949-G, 1950s Snap-Coupler All-Crop Drill, 1956 Roto-Baler, 1945 All Crop 60, Snap Coupler Subsoiler, Plow, Gleaner F, 505 wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 8:08pm
7040
Aren't you asking for trouble down the road with nothing but the taper of the bolts to locate the outer rim? There is no pilot. Mine uses the band spacer and clamps.
Takes a lot more brakeing to turn em
Edited by SteveM C/IL - 24 Nov 2015 at 8:10pm
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 10:09pm
   Thanks for adding the "braking" comment, makes a lot of sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2015 at 6:04am
but isn't the taper of the bolts all that usually locates the inner rim as well? I would be more worried about only 2 bolts locating the inner rim with duals on.  I think the t-rail duals with band are quicker to put on and off, but I've seen several people use both methods and they seemed to work ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2015 at 9:49am
Well the bolts method sounds an just about the same as the old bud rims on trucks and those worked good for duals for a long time. I have an old WWII military chevy 1 1/2 ton truck with duals like that on the rear. I just need to cut the centers out of the old split rims and convert it to modern rims. But I haven't had any trouble with the bud rims.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2015 at 10:28am
we had the snap on clamps  on the the duals for the  wd 45 and d17  you could have them on and off in five minets we farmed some very steep hills   kind off like you flat landers mountains LOL  so they were a must for tillage    i am also looking for a new set with  14.9s dont need them now  but what a set just for show
D17JIM2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM2 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2015 at 10:37am
We had the snapons on our wd-45 and Series IV D17 back in the mid 60's. they made pulling a disk in plowed ground much easier. We took the furrow side off to plow. We had 4-14 on both tractors and the land dualed wheel really held traction well. Dad always carried an extra wheel weight on the land wheel to help on traction before the duals. Once we had them we would never do without them.
LYNNMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LYNNMN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2015 at 10:45am
I have a set that bolts in the holes of the wheel weights
Lynn
Post Options Post Options   Thanks (0) Thanks(0)   Quote keith wd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 11:19am
got duals and need a lot of work but will look cool when done
