1961 d10 pilot bushing
billyrobert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote billyrobert Quote  Post ReplyReply Direct Link To This Post Topic: 1961 d10 pilot bushing
    Posted: 11 Aug 2015 at 1:25pm
need some help what are the step i need to follow to change the pilot bushing on a 1961 d10 allis chalmers and where can i find one . thanks
MrHDC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrHDC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 1:58pm
First thing I'd recommend is getting a shop manual for your tractor if you don't have one. As far as the part goes you can go to the AGCO Parts website as a guest and pull up the D10 parts manual. The clutch shaft bushing is in the flywheel group. Try a local AGCO dealer with the part number. If no luck give Schmitt & Sons in Mt Hope, Kansas a call. (800-281-2164)They've been real helpful. A lot of folks go to an Oilite bushing. It will last a very long time. You'd have to measure ID/OD/length to get one that will work and find a supplier on the web. You can also call Brenda at Sandy Lake Implement. She's great to work with and can find most any part you need.
Hervey
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 5:17pm
702281881BUSHING, clutch shaft (Prior to Tr. S/N D10-3501 & D12-3001)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 5:19pm
I would think if the bushing is bad, it's probably time to change the clutch, pressure plate and throw out bearing too. You're gonna have to split the tractor in half to do any of it.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 8:03pm
  bought mine at the dealer  not expensive
