Replacing Decals
jon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon Quote  Post ReplyReply Direct Link To This Post Topic: Replacing Decals
    Posted: 24 Sep 2015 at 5:12am
What is the best way to remove old decals and keep the original paint? Thanks for your ideas. Jon
easygoin4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 12:15pm
I alway use a heat gun, but careful not to get too close or hot..
Good Luck
jon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 12:53pm
Thanks for the suggestion, my real problem is that the decals are original on a 185 and really cracked. I guess that means just more time and patience.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 5:25pm
3M makes a spray on decal remover.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 5:28pm
Beware though on the decal remover spray cans...they also have a spray that will not only take off the decals, but the paint as well!  Rick
jon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 5:46pm
Wasn't there a buffing wheel also that you could use or am II thinking of something else. Thanks for the helpful ideas.
timr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timr Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 8:58pm
Yes you can get an eraser wheel however they can do some damage to anything that isn't cleared. A heat gun is probably your best bet. Be careful about what solvents you use too. 3m adhesive remover is pretty good about removing the left over residue but be sure to test a spot first to see if it removes the paint.
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 9:40pm
I don't think I would try any spray decal remover and the heat gun will not work on these old cracked decals as they are some good old tough decals to try to remove. I tried just about everything including the eraser wheel and the only thing that worked for me was to sand them off with the sander and 80 grit sand paper. You have to double tape off the edge of the old decal with green painters tape so you don't damage the good paint on the hood. Take your time and be careful doing this. Work on a small section at a time and walk away from it for a while so you don't get burned out. I have new exact size replacement decals that will cover where the old ones where down to a tee so most people won't even know you changed the decals out if you are interested.
Matt Folkers
FOLKERS RESTORATION
ogeechee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ogeechee Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2015 at 11:48pm
Oldoug,
Do you have the decals for the Allis Chalmers G? Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2015 at 12:51pm
I do not have any decals for a G. Sorry.
Matt Folkers
FOLKERS RESTORATION
GaryL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2015 at 12:54pm
Have you tried acetone?
