190xt slipping
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Topic: 190xt slipping
    Posted: 19 Oct 2015 at 9:59pm
Have a 190xt series 3 diesel. Been pulling loads of corn into town and I noticed sometimes after coming to a stop, I let out the clutch and the transmission seems to slip then it will come out of it right away. Also if I'm in the field and i have my front wheels cranked all the way to one side in road gear with the clutch out it won't move until I straighten them out. Any ideas?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 10:03pm
You need a new clutch.
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 10:08pm
i had the same problem with my 200 turn the corner and it would stop and then jump and take off i was told low hydrolic oil or some crap in my flow divider valve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 10:08pm
Or your PD is slipping...which could be nothing more than worn linkage which works the valve
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 10:39pm
I would say flow divider in pump needs cleaned and polish the spool. Linkage for PD has worn places. Bearings on linkage, bushing in torque tube that linkage cross shaft pivots in, cross shaft, linkage link to valve, and pins in that link.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 2:26pm
Well it was just in the dealer to get the pto fixed and the guy who worked on it said he found some bearing pieces when he drained the oil. He didn't have a clue where they came from.
