no high
mintenfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Topic: no high
    Posted: 30 Jul 2015 at 10:47pm
7050 had it for 14 years hi-lo went out slowly lever moves back and forth freely like a connector wire shaped is it easy to fix works without it in low
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 7:18am
May need some more info.  What you posted sounds confussing.
Are you referring to the buttons on the floor, that is the only thing I think that could go out "Slowly"
Or are you referring to the high low "lever" on the side console?  I can't imagine that going slowly, as it is a mechanical gear shift??  These are known for broken cable ends, and tight cables.  A couple hundred in cables and end parts will typically get you back in business.
If on the other hand you are referring to the buttons on the floor, that is a hydraulic two speed power shift clutch, and it can certainly cost some dollars, especially if by "slowly" you mean it was operated for a long time slipping,until it stopped working all together.
Still in use:
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 7:37am
The 7050 high, low, park cable is clamped at the rear of the tractor with a rather flimsy U shaped clamp. It uses two allen head capscrews to secure it. They have a habit of getting loose and that allows the outer shell of the cable to slip. The cable has a notch in it so that you get it located properly. The later tractors used a U bolt that was a much improved version.
