PTO delete question
skeeters65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Topic: PTO delete question
    Posted: 30 Aug 2015 at 5:03pm
Hey guys I got a PTO delete cover for my B. Do I just unbolt the PTO and it comes right out and put the delete cover on?
Also what is a PTO worth to sell? This one has the hydraulic pump with 1 ram attached to the rock shaft.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 12:50pm
Anyone??
fasstman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fasstman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 1:11pm
If you find somebody I have 2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 1:34pm
How do you get this thing out?
I got it unbolted and it only come out a half inch before it get hung up on the top shaft.
Help please!
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 2:29pm
Never mind I got it off.
I would assume you take the snap ring and the floating gear off and leave them both off?
Thanks
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 2:57pm
Off topic question: How much more rear wheel hp does a pto delete model tractor have then the same model with a pto?
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 3:51pm
That is an interesting question. I always assumed that the drawbar hp was tested when the pto was not engaged so it wouldn't make any difference.   But that is just a wag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 6:57pm
No clue.
I'm doing it cause I will never use it and it deletes a few places where the tractor can leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2015 at 5:23am
You're probably right
