CA transmission in a B |
skeeters65 ![]() Orange Level ![]() Joined: 09 Jul 2015 Location: CT Points: 371 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Sep 2015 at 8:18am |
I think I have read that this is a direct bolt in.
Is that true? The CA is a 4sp correct? What is the top speed of a CA compared to a B's 7mph? Thanks |
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
At rated RPM (not max) the B is 8mph and the CA is 11.25 mph according to Terry Deans tractor data book.
Is the CA a direct bolt in in the B?
Do you lose any low end power by doing this swap? |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
you would gain pulling power by better gearing. My CA will easily output my B
Charlie
sandman2234 ![]() Orange Level ![]() Joined: 21 Feb 2013 Location: Jax Points: 2547 |
Rather than change the transmission, I see a good excuse to go buy a CA tractor if you need something with a little more speed!!
David from jax |
A proud member of the Allis Express movement!
Northeast Florida |
AJ ![]() Orange Level ![]() Joined: 31 Oct 2010 Location: mo Points: 5244 |
Yes. It would be a bolt in if you want to go through the work of doing it.
Can't fix stupid
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
If the motor I the problem in the CA you'd be better off putting a B motor in a CA.
DonBC ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 945 |
If the the top gear is straight through on both transmissions then the top speed would be the same for both transmissions.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
It would be a direct bolt in but you can't compare data sheets to come up with mph speeds. The testing published in a data sheet would have been done on different size tires on the B than the CA.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Also, the early B's had a lower RPM than the CA if I am not mistaken.
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Dick L and Charlie, Very good!!
If I recall from memory - and it is not all that good - the late B's had about 1500 rpm the earlier B's had less, while the CA engine has at least 1650 perhaps more rpms. However, you would get some benefits with a lower gear and a higher gear and the helical gear transmission. Let us know how it goes. Good Luck! Bill Long Edited by Bill Long - 12 Sep 2015 at 3:33pm |
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10918 |
If your changing rear end and all you will be gaining hydralic, different hitch and spin out wheels.
Tom |
www.tractordata.com has basically the same info that Ted mentioned. A(7 to 11 mph). Since both use 24 inch tires, roughly the same height, I would think that something else is causing the difference. The RPM's definitely a difference, but what about the bull gears in the finals? I know there are different tooth configurations in the B and C history, so wondering if that is also a factor.
David from jax |
Northeast Florida |
Both 24 inch rims but the wider the tire the taller they are which makes them farther around or faster at the same rpm. |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5108 |
The CA transmission will bolt into a B or C. I've seen this done a few times. I agree with those above that if you want a 4 speed little tractor this would be a good reason to get a CA. The foot rest bar and seat mounting will need to be modified. The reason a CA will out pull a B or C at the same weight has more to do with the slanted back final drives and the longer wheelbase which gives better balance. Not only are the transmission ratios different the ring an pinion and final drive ratios are also.
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Thanks Paul
The 4 speed CA is longer than the 3 speed B/C transaxle by 2 and 1/4 inches making other mods necessary. Will B finsls bolt to the CA TA? Are the axle spines the same? Maybe easier to change from the clutch back if the B steering box bolts to the CA torque tube. Didn't late Bs use a CA Torque Tube tube? I would have thought a shorter wheelbase would give better balance. Them short IBs sure pull good. |
