WD45 Hydraulics Problem
Rod Yowell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hydraulics Problem
    Posted: 19 Jun 2012 at 2:25pm
I have a WD45 that I had to replace the torque tube. I have it back together now and I am having trouble with the lift on the hydraulics. It will raise and lower slowly by it's self. It will lower very rapidly if I stand on the 3 point hitch. But It will not raise if I am standing on the hitch. It only comes up without a load on it.
    Any suggestions?
Edited by Rod Yowell - 19 Jun 2012 at 2:25pm
Socialism is the Philosophy of Failure, the Creed of Ignorance, and the Gospel of Envy
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 7:47pm
Are you sure you have the linkage adjusted right?? A good manual tells you how to do it. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 8:07pm
It was supposedly adjusted right by the fellow I bought it from. He says that he didn't have any problem with it before he broke the intermediate gear and the PTO housing while brush-hogging.  I am trying to check in the 'Service Manual' and the Operating Instructions & Repair Parts Illustrations manuals that Mike loaned me now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 8:12pm
Thats the first thing I would check Rod. Also make sure your fluid level is good. Its just another thing to eliminate when diagnosing a problem. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 8:28pm
The fluid level is full. One thing I noticed though is when the tractor is running I can remove the filler cap on the torque tube and look down where the return line is connected and I don't see any hydraulic oil coming back into the reservoir. Is this normal. I would think that there would be movement of oil if it is circulating.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 5:34pm
I keep a pressure gauge on my remote at all times. Call me crazy but I just like a window into the system. If you had a gauge on there I'm sure you wouldn't see any or very little pressure. Unless your very low on fluid there is no way it can't be pumping fluid. Problem is its all going to return internally. The WD45 repair manual has a very good explaination of the pump and how it works internally. I've studied this pump and I still have had questions about its operation but have a pretty good handle on the basics.
