7060 won't shift. help!
BurdMan660 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BurdMan660 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 won't shift. help!
    Posted: 20 Jul 2015 at 11:24am
Hey guys, I stopped to shift my 7060 a couple days ago and I pulled the floor shift lever into neutral and it would not go back into any gear. The tractor is definitely in neutral and the stick wiggles around, I just can't push it into any gear. Anyone have any ideas?
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 11:33am
Does it just grind when you are trying to get it in gear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BurdMan660 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 11:35am
No grinding. Stick moves side to side like normal but I can't push it up or down into a gear.
Shawn PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 11:42am
might be stuck between gears ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote BurdMan660 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 11:50am
It's def in neutral because we towed it out of the way.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 1:22pm
Was the two speed in neutral also or in a range when you towed it?  Was it running when you towed it?  The trans could be stuck in gear, and if the two speed was in neutral, or the engine wasn't running you would still be able to move it.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote BurdMan660 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 1:26pm
It was in low range and the engine was running.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 1:38pm
Is there something stuck like a small stone or a nut under the steel shifter umbrella> You know, where the floor mat meets the stick.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote BurdMan660 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 1:46pm
It kinda feels like hydrualic pressure preventing the stick from moving into gear...
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 2:04pm
There's nothing hydraulic about that gear shifter. Sounds like something under that umbrella...............hopefully.
Wink
I am a Russian Bot
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2015 at 8:02am
Didn't come completely out of gear, so the innerlocks are keeping it from going into another gear. Remove gear shift and look into hole. one shifter may not be ouite lined with the others.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote BurdMan660 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 5:13pm
Mack, You hit the nail on the head. pulled the floor plate out and took the top off the tranny and got things freed up. Thanks a bunch.
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 5:31pm
The next time it happens you can just pull snap ring off of shifter pull shifter strait out and realign with screwdriver don't ask me how I know
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2015 at 10:37am
I had an Intl 560 that would do that routinely
I had found a piece of steel that fit the forks and would need to use it three of four times an hour when pushing snow.
The reverse to first was the worst
AC7060Pd 1975
