Allis wd45 need more rpms
randywd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randywd45 Quote  Post ReplyReply Direct Link To This Post Topic: Allis wd45 need more rpms
    Posted: 11 Aug 2012 at 8:59pm
Whats the easiest way to crank more rpms on my wd45?
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 9:20pm
Tie a piece of binder twine to the gov.rod and pull. Lol!Big smile
Edited by Mike NEIN - 11 Aug 2012 at 9:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 9:40pm
Why?
Post Options Post Options   Thanks (0) Thanks(0)   Quote randywd45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 10:08am
for pulling
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 10:21am
  Been there done that..... Didn't help, pulled better stock. There is no substitute for cubic inches, and high compression!    To answer your question, a D19 gov. spring will get them up there..
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 12:45pm
A D17 governor spring will get you 2000 rpm. A D19 spring ?? I doubt it will even fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 12:57pm
Originally posted by randywd45 randywd45 wrote:
for pulling
Sometime down the track, your governor will have the throttle pulled wide open. No matter how fast it runs at the beginning, you will still have the same throttle position and power when this happens. All you would be doing is increasing the no load speed of the engine and will no effect on what you can pull or how far you can pull it.
