Help with tires
orangeman Ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Ia Quote  Post ReplyReply Direct Link To This Post Topic: Help with tires
    Posted: 13 Aug 2012 at 8:10am
I have a 6-00- 16 tube tire and I can't see on the tire what the correct air amount is, you guys know? Thank you.
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 8:14am
What are you going to use it on? I run 40 pounds in hay wagons. Front tire on tractor 40-50 unless using loader then 70. Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 8:16am
The front tire on my 45
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 9:48am
No loader 40 pounds would be max. Depends on how she steers. 32 might be enough. Bill
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 9:52am
Most of that size unless it is 6 ply or truck rated would be 32 PSI.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 11:24am
i run 40 in mine
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 4:01pm
Front tires on WD 45 are 25psi. 12 psi in the rears
