Motor stuck?
Gleaner6879 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gleaner6879 Quote  Post ReplyReply Direct Link To This Post Topic: Motor stuck?
    Posted: 12 Aug 2012 at 9:58pm
Went to look at a tractor recently for a possible purchase.  It had sat a few years and outside to boot.  Wouldn't turn over and even with help of jumper cables on the solenoid, only could get the "clicking" sound of the starter.  Is it possible that the motor is stuck?  Can't say I've ever tried to start a motor that was stuck, so I'm rather ignorant of the symptoms and/or signs to look for.  A little education, please.  Btw, the muffler did have a rain cap on it.
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 10:19pm
It could be anything from the starter being stuck or jammed in the ring gear to a totally junked engine with anything in between possible. If you want the tractor, buy it as needing a complete new engine.
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 10:34pm
The thing about buying a tractor with a stuck engine is, you can't check anything out on it. You don't know if the transmission got trashed and then it was parked and the engine stuck. So now you have to get the engine unstuck, rebuilt and then you find out the transmission or rear end is trash.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 6:50am
I bought a WD-45 that sat outside for probably 15+ years, got it home pulled the motor and it spun right around. If it has a hand crank give that a try, but if the starter is stuck on the flywheel you might have to pull it out to try. Hope this helps.
Edited by Josh Day - 13 Aug 2012 at 6:51am
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 6:57am
I would pull the starter off and use a bar to see if the engine will turn. And yes I agree that as it sits it is just a parts tractor.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 7:02am
what mod is it if it don't have a hand crank try to turn the front pulley
