K Gleaner Hydraulics |
Robbpend ![]() Bronze Level ![]() ![]() Joined: 25 Aug 2014 Location: Florida Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Jan 2015 at 11:30am |
The combine has power steering, Hdy variable reel speed, and Hdy reel height control. The reel speed and height controls work fine when just starting the machine, but after about an hour of running the controls get slower and slower until they will not respond. The power steering, header height and variable speed still work. I can spray water on the Hdy pump and the reel speed and height will start working some, but very slow, and will eventually stop working again. Is this just worn pump or could it be something else? The Hdy filter and oil was changed, but the problem is still there.
thanks, Robb |
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
sounds like it's heating up. I don't have power steering on mine. might be sucking air or getting air pockets in it
thunderbird ![]() Silver Level ![]() Joined: 31 May 2010 Location: Iowa Points: 73 |
Look for a clogged oil cooler. It may just need to be washed out. Are you using type A transmition oil?
waltw ![]() Bronze Level ![]() Joined: 17 Sep 2009 Location: williston Fl Points: 39 |
Since header lift and traction drive variable speed works I might look at the control linkage. Something may be bent worn are lost .
There are two hydraulic circuits that dont work properly but there both activated by same lever in cab. |
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3535 |
My guess: Hydraulic pump and/or hydraulic flow control valve is(are) worn or internally cracked. When the combine is initially started, it's hyd oil is cold and thicker so the worn or cracked part('s) leakage is less noticeable. After the hyd oil heats up, leakage volume increases.
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3526 |
common, replace the pump. Also remember - keep those header helper springs as pushed up tight as possible.
