tool for loading tires?
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: tool for loading tires?
    Posted: 25 Aug 2012 at 9:11pm
Where can I get the adapter to load tires with water from a garden hose? Im looking add about 500lbs of free weight for pulling. also doesanyonte have a liquidballast chart? i dont want to add too much. the plan is to drain it out at the end of the season to prevent freezing. i wont be using the tractor in the winter because i live in a trailer park an they have snowplows already
Edited by AC WD45 - 25 Aug 2012 at 10:04pm
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 9:24pm
I don't know if this is what you are looking for or not?
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 9:25pm
got mine from napa here in marshal texas.any napa store should carry them...
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 9:33pm
I took a supply to a clothes washer and cut 1 end off and slid the hose over the valve stem and clamped it fast. Connect the other end to the hose and go for it. If in loading the tires with CALC I connect the hose to a small sump pump. LOL Bob
Edited by Chalmersbob - 25 Aug 2012 at 9:34pm
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 9:50pm
got mine at Tractor Supply
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 10:04pm
so if my math is correct i need around 30 gallons of water in each tire.
German Shepherd dad
#WD234847
#WD88193
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 11:19pm
No reason to drain it for winter if you won't be using the tractor. The tires can freeze solid and it won't hurt anything as long as you don't move it while frozen.You'll never be able to get it all out anyway by draining.
Edited by m16ty - 25 Aug 2012 at 11:21pm
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 4:47am
I got mine from gemplers. what I had planed on trying to do was use a piece of hose hooked to a barrel pump then hooked to the tool for putting in water. then I was going to fill the tires with used anti freeze from a 55 gal drum. I never got to try it, my 8n had only 1 tire loaded with anti freeze and I almost rolled it over, since all the wieght was on one side, I sold the tractor before I could try loading the tires myself.  I don't see why it wouldn't work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 7:34am
Farm and Fleet stores usually have them at the air chuck etc display.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 8:30am
Closer to 50 gal.
 I just loaded one of my 14.9X28 tires and it took just under 50 gals.
With 2 lbs of CaCl per gal, that's just about 500 lbs of extra weight right where you need it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 9:41am
Originally posted by Brian G.  NY Brian G. NY wrote:
Closer to 50 gal.
I believe he wants to add 500 pounds total to the tractor, not 500 pounds per wheel.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 10:52am
This might help ya, I went through this a while back.
It's  a slow process.  I should update this post someday, since I have now used the things I got....
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 12:00pm
Water (with nothing added) is about 8.35lbs per US gallon.  If you want to add 500lbs to the tractor's weight, that's 250lbs per wheel, or 250/8.35= 29.94 gallons.
Draining as much of the water that you can, is very advisable, particularly in your lattitude- when water freezes, it forms a crystalline structure that occupies more space, than in it's liquid form.  28.6 gallons of water will fill a 13.6-28 tire halfway.  If you freeze the tire at that level, there's a definite likelyhood that you'll wind up with a broken rim, and broken belts in the tire carcass.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 12:06pm
If anyone is looking I have aprox 100 gal of Dow-Therm chiller antifreeze (not for engines) that can be used for tire fill or for in floor heating systems.
For a tool I used a piece of plastic hose to fit over the valve stem and clamped it onto stem, then converted other end to air hose fitting , as the tire fills you need to bleed the air out every so often so you are not creating a back pressure against pump or air binding system.
Edited by Coke-in-MN - 26 Aug 2012 at 12:38pm
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 12:17am
We used windshield washer fluid & rigged up a swamp cooler pump to pump it in the tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 9:55am
Thanks guys I bouht the tool yesterday and put aboout 30 gallons in each side. Worked great!
German Shepherd dad
#WD234847
#WD88193
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 1:55pm
I get used antifreeze from my mechanic. He's glad to get rid of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 3:40pm
I don't want to have to buy a pump. Idc how cheap they are I'm living pay check to pay check
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 6:59pm
I took a 3" pvc pipe, about 2' long. Reduced it down to a hose spigot and hung it about 4' high on the wall. I hook a hose from it to the adapter and to the tire. Put the valve stem on bottom and let the tire flat before hooking up the hose. Pour antifreeze into the pipe and let it feed into the tire. It's slow as molasses, but it works. After I get about 5 gallons in, I hook it to the hose bib on the barn and finish filling with water. You will have to stop periodically to let the air escape as the tire tries to build pressure. Remember, water pressure on a building is around Fifty pounds or more, so don't let it over pressure.
