model wc
dlong83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlong83 Quote  Post ReplyReply Direct Link To This Post Topic: model wc
    Posted: 22 Aug 2012 at 12:12pm
i just picked up a wc unsure of the year as of now. i found the serial number chart on the site an as soon as i get a chance ill know. alot of the pictures ive looked at of newer models have a distrib this one has a mag and is styled. any ifo out there what to look for beware of?
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 3:43pm
All WC's came with mags the ones with distributors have been retro fitted.  Here is a bit of information on the WC:
http://home.comcast.net/~old_allis/WC-data.html
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 4:55pm
Welcome to the forum, Good tractor lots of fun. Just post lots of pics and give us specific questions. You will get answers and good luck with it.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 5:31pm
Styled WC's were built from 1938 till the WD came out in 1948. The chart on this site lists the LAST number for the year till you get to the D series tractors. It seems it is easy for people to get confused this way but that's how it is.
Edited by CTuckerNWIL - 22 Aug 2012 at 5:34pm
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 5:58pm
Welcome, you've picked a good tractor to get started with.  Plentiful and reasonable priced parts and lots of knowledge on this board.  Have fun!
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlong83 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 8:29pm
numbers on the back say wc92442 and im not finding that on any of the listings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlong83 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 8:34pm
i have it figured out its a 39 thanks for the help and any more info on is awesome. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlong83 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 8:51pm
Nope, it's a 1940. The number listed for each year is the LAST tractor for that year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlong83 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 8:52pm
are these original wheels for the tractor ive seen alot of pictures but none with these wheels?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 8:57pm
No, the styled WC's had a cast center with rim clamped on. The 24 inch spoked wheels would be from like 1936 or earlier. Not sure when they changed to the stamped steel 24 in rim.
This would be the original wheel set-up for a styled WC.
http://www.tractorshed.com/photoads/upload/393595_opt.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlong83 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 9:01pm
ok makes sense now. on top of the transmission there is some sort of box with a wheel off the side with two spring loaded arms on it and there is a pedal to engage and dis-engage it as well as a lever can ayone tell me what this is/ looks like some type of centrifugal clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 9:16pm
That is the cultivator mechanical lift powered of the back of the tranny. Most that had that also had a disconnect for the differential so you can raise the cultivator without moving you wheels. The lift only turns if the tranny is in gear and the clutch is engaged. So , if you drop the cultivator and don't have the disconnect, you have to actually turn the back wheels to get the lift to operate.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 7:09am
Looks like a nice tractor -- lots of enjoyment ahead for you (mixed with a little frustration now and then - LOL)
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 10:57am
The last unstyled WCs had 24" pressed steel wheels, as did the first styled ones from 1938 & 1939. Your spoke wheels are the same size as the pressed steel ones but from an earlier unstyled WC. After late 39 or early 40 WCs changed to the two-piece cast center wheels and went to 28" tires.Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlong83 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 8:39am
Has anbody had trouble out of there front main leaking like crazy? And does anyone have a PN for a carb kit ?
WC Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Dale Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 11:55am
It's been my experience that it is usually the front pan gasket that leaks so bad and not the seal around the crankshaft. Might want to confirm which for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 12:55pm
If it is the front seal, it might be necessary to loosen the front cover and realign it. There are no dowel pins on the cover and the seal bore HAS to be lined up with the crank before tightening down and adding the seal.
