Hah... Sticker shock!
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Topic: Hah... Sticker shock!
    Posted: 09 Aug 2014 at 2:20pm
I'm in the process of replacing ALL my filters, save one, the strainer in the back hydraulics.
parts man said just clean it, if it is damaged and needs replacing, I have far bigger issues to deal with than a filter.
so, ALL filters totals $396
Oil, $450. 6 Pails
so, after taxes, will be just under $1k (plus gas as it is around 1hour's drive)
but then, I "Should" be good to go!
(oh, I'm getting two of each except the bypass ( long change intervals ) and the Outer air/Inner Air as I can clean those
I plan on new filters/oil every fall before it stop for the winter, in case I need to use to for something.
AC7060Pd 1975
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 8:56pm
Wix filters offer volume discounts.  My local car parts supplier allows people to purchase filters under a local business name and use their discount.  I think the final cost was around 50% off list price.  The business doesn't care as the increase in volume results in better discounts for them.
You could ask your local Wix dealer if they will order the filters in under one of their business customers and use their discount.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 9:05pm
Check Amazon, sometimes you get a pleasant surpriseSmile
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 9:05pm
That sounds about normal anymore. Sad but true.
We have some new tractors that the hydraulic filters are over $300 EACH. Not like the good old days!
Jim
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 10:02pm
I changed the oil on my Kubota M110 last month and discovered I didn't have another filter in the closet for it, of course it was on Sunday afternoon.  Drove 12 miles to a Napa store, no but they have one in Berthoud, about 10 miles further.  Drove up there to find they closed 20 minutes before I arrived.  On Monday I found my usual parts store didn't have the Wix filter and wouldn't for a couple days so I drove back to Berthoud, paid $23 for it and then a couple days later, paid about $9 for the same filter at my regular place.  Where you get your filters does make a difference.
Edited by JohnCO - 09 Aug 2014 at 10:04pm
Allis Express participant
Nebraska Cowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nebraska Cowman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 5:30am
I'll 2nd that. I have bought several filters from Amazon.
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 5:53am
What kind of oil are you using thats 15 bucks a gallon?  Well for my self if oil is that high id go 5 yrs on the rearend and hyd as none of my tractors get very many hrs instead of the the 3 yr intervals we do now!!  Kurt
WD D17D 170 190xt 190xtIII 200 7020
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 6:03am
yikes !!!don't mean to be mean but I've bought complete RUNNING D-14 for less than your filters/oil change. I know not quite the same but yeesh....
SSS ( stupid step son) bought a new Dodge 1/2T with 3Litre diesel. oil/filter changes will run him $200+taxes= +-$250. My gas F150 is <$50.
One thing about Amazon,they sometimes say where/who is supplying the products.If so go to their website and you may get a better deal. I got a voltage regulator for the 8N from GB electric( or BG ) $10 LESS than Amazon AND free shipping.SAME identical regulator 5 minutes away was $100, from GB  it was $24 !!! so it pays to spend time with Google and learn how to search !
cheers
jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 9:40pm
amazon won't work for deals up here... shipping is often more than the product
Kurt, AC oil from the nearest AGCO dealer.
same with all the filters... going to go with AC/AGCO for now.
Case HyTranUltra is over $75 a pail, same with the JD stuff....
but if my maintenance program is around $1k a year....  I'd be OK with that.
it is the other things that haven't happened yet that I worry about.
AC7060Pd 1975
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2014 at 1:01am
after I bought the Case, it was in the dealer for something else, and like a dumb chit...told them to replace all filters and oil while it was in there (winter time) and after $1800 for them to do that...(just filters and oil)
Post Options Post Options   Thanks (1) Thanks(1)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2014 at 12:59am
Maybe they thought you meant ALL the tractors at the dealership!
This page was generated in 0.069 seconds.
