loss of drive |
DAK2 ![]() Bronze Level ![]() ![]() Joined: 12 May 2013 Location: WILMORE PA Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 12 May 2013 at 4:50pm |
I have a 190xt 3 and today i was plowing and would temporarily lose hydraulic pressure i guess the steering would get hard and the 3 point hitch and cylinder on the plows would get choppy and not work when this all would happen the tractor would not move then all at once it would take off ,check the fluid full even after i unhook the plows it still acted like it was jumping out of gear or into neutral then back in gear i kind a think maybe the main pump is going out has anyone else ran across this before
Did you check the oil on left side of gear shift? It sounds like low on oil. If it is full, check all the clamps on big suction from bottom of torque tube to pump. If it is a early 190XT, pull the flow divider out of manifold on back of pump, polish it. MACK
ILGLEANER ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
When I saw the post I thought you were talking about me. My wife says I have lost my drive to get things done around here.......LOL
IG
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4542 |
I thought the same thing when I looked at the subject line. I do suffer from that and need a fix. Too many projects and not enough drive.
XT in pa ![]() Orange Level ![]() ![]() Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
mine just did bout same thing only it would move fine i polished flow divider and rebuilt my hyd. pump works great now not saying you need to rebuild pump though .
Shawn
190XT,D17and 7045
GlenninPA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
I got plenty of drive, but seems like the projects just keep gettin stacked on, so as not to be able to get ahead of the curve!
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
Goose ![]() Orange Level ![]() ![]() Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
When I saw the post, I was going to suggest Viagra or Cialis.
"People are human beings, produced by the society in which they live. You encourage people by seeing the good in them." ~ Nelson Mandela
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Cialis ? You mean C Allis?
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11994 |
That's funny! I thought the same thing when I read the title line. I guess us old guys automatically think that way. Glenn, you need to take some of that drive and start hammerin' at your projects before the drive goes away! C'mon son, git' wit' the program! Stop pilin' and start doin'! LMAO!!
Steve,
I ain't the one doin' the pilin'!!! Workin' like a dog, gettin' a lot done, but can't work faster than rate the pile is growin'... I think I need a couple more tractors to help take some of the work!
