170 engine suffix ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: 170 engine suffix ?
    Posted: 06 Oct 2012 at 5:10pm
What does the letter M, and Z mean at the end of engine serial number? Thanks Tracy Martin
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 6:41pm
 M code engins are found in most D17's,   170's  and Gleaner E111's have a little more compression an those are z code. D 17 lp and 175's have even more compression and are V code engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 8:30pm
I was wondering. I have an M code and 2 that have the Z code. Thanks Tracy Martin
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 8:36pm
The M code is 7.2:1 compression ratio.  The Z is 8.0:1 and the V is 8.2:1.   Of course all that's different in the engines to change the ratios is the piston heights, so who knows what is actually inside on a 35 to 50 year old engine.  I know of an M engine for example, with 8.2:1 pistons in it.
