L2 problems
jjpetrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Topic: L2 problems
    Posted: 26 Sep 2012 at 3:32pm
Combining beans and the steering and header up and down doesnt work.  I figured that it would be the hyd pump just wondering if that would be likely.
On the farm wd,wd45,180,200,7020,8010,8050,f,L2,2 b engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2012 at 3:38pm
Don't run it any more until you make sure the belt is on the hydraulic pump. WHAT MODEL YEAR IS IT???????
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2012 at 4:57pm
The belt was on and i believe it to be a 79'    serial# L-k19871z
Edited by jjpetrich - 26 Sep 2012 at 5:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2012 at 6:20pm
That is a 1980 model and would have a tan colored cab interior. If it is a hydro model, you have a twin-section gear pump with hydro charge being supplied by one section...that is why it's important to make sure the belt is on, as you will destroy the hydro if the charge pump isn't working. Make sure the machine will move before anything else, if it is a hydro. The second section is for your steering and header lift (and all other hydraulic functions as well). I'd be thinking internal pump failure of the steering/lift pump section.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2012 at 9:45pm
Will any other hydraulics work? Make sure the pump shaft is not broke. They will break just inside the outer bearing and belt will be tight. Try to pry the pulley away from pump. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 12:51pm
Took the motor off then the shaft broke off.  Thanks for the help guys!
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 6:48pm
1981 was first year of tan interior, but you got everything else spot on.
1980 and up machines kept the belt on much better due to a new idler and spring arrangement and double (versus single) belt.
