Removing WD45 frame rail to pull engine?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Topic: Removing WD45 frame rail to pull engine?
    Posted: 29 Sep 2012 at 7:09pm
I seem to remember that the generator side frame rail can be removed to make it easier to pull the engine out of a WD45?  My service book said nothing about this.  Pros and cons for doing it?  It's a narrow front.
Edited by Stan IL&TN - 29 Sep 2012 at 7:09pm
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 7:16pm
NOT NECASSARY  UNBOLT STEERING WHEEL SUPPORT THEN CAN TURN IT ENOUGH TO REMOVE DONE IT MANY TIMES AT DEALERSHIPsecure crank rod forward with vise grip
 after removing bolt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 7:29pm
So the reason is because the steering shaft is in the way?  And if the shaft is out then the engine will come forward and then straight up as long as the hand starter is pulled forward and held there with the vise grips?Smile
1968 one-seventy
1956 F40 Ferguson
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 10:32pm
Yup.
AaronSEIA
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 10:48pm
I removed the radiator to give me more room.
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 11:25pm
Thanks everyone!  I think I got's it now. Thumbs Up
1968 one-seventy
1956 F40 Ferguson
