HD4 hydraulic 10-30w ?
rentedhubbie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rentedhubbie Quote  Post ReplyReply Direct Link To This Post Topic: HD4 hydraulic 10-30w ?
    Posted: 14 Jul 2011 at 2:48pm
I have a new to me AC HD4, It needs oils changed as they are "milk".
 I have found the sticker that tells what goes where and what it is. But some of it is "RIB" = "read in book" and others confuses me,
The converter oil says use "A" type. I found hydraulic oil thats AW ISO 68 and ISO 100 in my shop. Is this the right stuff?  what do I use?
 next the hydraulic reservoir for the loader rams say use SAE 10-30w.
Its not hydraulic oil? Standard motor oil? Is this correct?
 I have no numbers for filters or anything really.
 Thanks, Anything you can do to help is really Great.
Todd, the rented hubbie
John(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 3:33pm
The type "A" is ATF.  My books are not here but over at the location of my HD-4 or I could give you the spec for all the oils.
Edited by John(IN) - 14 Jul 2011 at 3:35pm
Learn something every day!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 4:19pm
Type A in torque converter, hyd fluid in hyd reservoir,I like Rotella 15-40 in engine, 90 wt gear oil in finals. Rollers use 90 weight with button fitting if not changed. HTH Tracy Martin
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 4:31pm
they called for 10/30 as the hyd oil has to be a good anti-foam and anti-wear property also.
mike l View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike l Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 4:44pm
which oil in the 3 speed trans?
