ALLIS-CHALMERS D17 Series III
jmfonzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmfonzy Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS-CHALMERS D17 Series III
    Posted: 01 Mar 2012 at 12:30pm
I was going to sell my tractor restoration project, but I think I have decided to keep the old girl and finish the job I started.
So because I am keeping the tractor I want an Allis front end loader for it. Any thoughts on where I can find a good one for cheap in Oklahoma?
Jon
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 2:22pm
Well, not off the top of my head, but if you like I might be able to help you out some.  Will be heading south out of central NE in June sometime, with an empty flatbed, headed for Oklahoma City.  Would be willing to discuss some hauling options if that would expand your search area some.
I do have a non Allis full hydraulic loader off of a D17, that I might be interested in selling.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmfonzy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 5:31pm
Well that is certainly something to consider. I'll keep it in mind and if I don't come across anything I'll get with you.
Thanks,
Jon
Jon
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmfonzy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 5:36pm
OK! Now I got another issue. I was messing with my tractor today and started it up from a jump. ran it for abour half an hour and the battery is dead again. Since the battery and generator, regulator and solinoid, starter and ignition coil, wires and plugs, etc. are all new I am befuddled as to why my battery is dead. It must have a dead cell in it. It's only around 9 months old. Any thoughts?
Jon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 6:01pm
Did you repolarize your generator when you pull all those new parts on?  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 6:04pm
It could be a bad battery, or it could be a poor connection.  First, double check all of your connections, at the battery, the starter, the solenoid, and the starter.  Make sure they are all clean and tight.
I know you may know some of this stuff, so I hope I don't insult you.  If the genny wasn't flashed when you hooked everything back up, it may not be charging, what does your amp gauge read while running, and not running, but lights on?
The other thing you can do if you have a buddy to help you, is to put a volt meter on the battery, not the cables, but directly on the battery post, and try to start the tractor, and see what the meter reads for voltage.  If it reads up at around or above 12 volts, while it won't roll over, then it's not the battery, if it falls lower than say 10 volts, it's probably the battery.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 6:07pm
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
skip(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skip(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 10:38pm
i didn't have one of the connections right when a put a new voltage regulator on mine, it'd start, run, and charge just fine, but once i shut it off, the amp gauge needle was almost buried in the negative zone. not saying this is your problem, just throwing a thought out there.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 6:29am
I have a fully hydraulic loader off of a D-17 series4 that I am taking to the Allis Chalmers swap meet south of Harrisonville, Mo. this weekend. On 71 highway North of Joplin. I am asking 750.00 for it. I expect it to sell this weekend, taking it up today.  Dave.816-918-3840, 816-320-3282
