210 LOSS OF POWER
gleaner000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner000 Quote  Post ReplyReply Direct Link To This Post Topic: 210 LOSS OF POWER
    Posted: 05 Jan 2012 at 12:00pm
WE HAD OUR 210 FUEL PUMP RE-DONE BY OUR LOCAL DIESEL PLACE(DIESEL EQUIPMENT 48876 GREAT PLACE!).  THE TRACTOR SAT FOR A FEW YEARS WITH A BROKE DRAWBAR BEFORE THAT.  NOW THE SAME TRACTOR WONT PULL THE SAME THINGS IT DID BEFORE. ANY IDEAS?
schwanman66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote schwanman66 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 12:02pm
Have you changed fuel filters?
1970 & 1971 190xt Series III's & 160
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 12:03pm
pump not turned up enough?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 12:14pm
they probably set it back to stock when rebuilt. Was likely set hotter than you thought, you may have thought it was all stock. there is a chance it is set wrong or to the wrong spec. dyno will tell the story. Is it timed right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote schwanman66 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 12:23pm
If the setting were altered from previous setting, wouldn't you see the a change in smoke at load from before and after?
should be less smoke I would think
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner000 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 2:52pm
the timing is right, had a hell of a time getting it to line up...  as far as the smoke, im not sure. it sat couple years w broke drawbar.  is there a setting to change the mark on the pump?  housing is turned all the way to the block to line the marks up
its as if i hook the disc on it, it falls on its face.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 4:22pm
check to make sure the return line from pump, across top of injectors, and back to side of tank is clear. the broken flex ring particles from past problems may be restricting the free flow of fuel out of pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schwanman66 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 8:14pm
Like Ed said above, there is some type of fuel restriction somewhere.  In the past when pulling in the field lack of power always seemed to be injector pump or fuel filters.
larrySEARK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote larrySEARK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 8:27pm
make sure the fuel shut off cable is opening the fuel fully. had that happen once.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 8:39pm
Check everything mentioned in the last few posts, but as Ed eludes to, many many many D21 and 220s were factory "tuned" by the dealers to really smoke the competition on demo days.  Our D21 which we are fairly sure has never been touched until we rebuilt the pump last year, has significantly more HP than the book says it does.  Since dad doesn't farm with it anymore, he had the settings put back to stock, and it ain't the same girl she once was.  Our big disk buried to the hubs never used to bother her in 5th with duals on.  Now I don't think I could pull it in 3rd with the stops in. :-(
Still in use:
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 10:09pm
Check to see if your turbo spins freely, just a thought. Darrel
FHOliver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FHOliver Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 11:44pm
air filter/mouse nests ?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 7:24am
Old fuel still in tank?
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner000 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 7:27am
i will check all the fuel issues mentioned. thank you.  air is clean and free.  ill be back to follow up
i will look into the fuel issues and reply back. thank u
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 7:28am
My 220 sat a couple years before I bought it.  When I first took it to the field it struggled to pull a 16 ft. Harrowgator over 1500-1700 rpm in 4th.  After a few hours it gradually picked up rpms and I shifted to 5th and would pull just fine.  Been running strong ever since.
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 9:24am
make sure the fitting/shutoff valve in the bottom of fuel tank is open and not restricted by junk or dirt. you will have to unsrew fitting from tank to see for sure. you would be surprised at what can get packed in there and tractor still run.  p/s i found a piece of a red shop rag in mine, kind of a prefilter lol
