ca ignition timing
oconeeallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oconeeallis Quote  Post ReplyReply Direct Link To This Post Topic: ca ignition timing
    Posted: 30 Dec 2011 at 12:06am
after replacing the distributor in my allis CA i don't know how the gears should match up. help please!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 5:46am
Check for the compression stroke for number one cylinder and get the TDC or CENTER line in the center of the inspection hole. Set the distributor down in the hole with the rotor pointing to the number one plug terminal when all the way down. With the power on rotate the distributor base back and fourth looking for the spark at the points. Lock the distributor down when you have the points closed just at the point that they are about to open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oconeeallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 9:04am
thank you very much for your help
This page was generated in 0.035 seconds.
