Looking at 7060
dnel45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Topic: Looking at 7060
    Posted: 13 Mar 2012 at 9:02pm
We are looking at a 78 7060, decent shape, 4000 hrs. I have a few questions. It has a powershift transmission and it seems the clutch pedal has a slight rattle noise when you press it down slightly, but not all the way to the floor when the brake comes on. The position in the clutch pedal where it rattles is right after when the tractor starts to coast and right before it auto brakes. It doesn't sound like grinding but more of a chatter. Is this typical of a powershift? Also it seems as though the clutch pedal presses easily, I have never driven a powershift before though and the only thing I can compare it to is our 200 clutch, which presses hard. There's a few hydraulic leaks from the back end, can't tell where they are coming from without cleaning it up good and taking a look. Also, a very small engine oil leak seems to be coming from the main seal?   Assume these leaks are somewhat normal for a 34 year old tractor. Anything else we should know about 7060s? Thanks for your input.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 10:33pm
The clutch will push easy because you are only moving a spool valve. The clutch pressure comes from a spring under the dash.
  The noise you hear should be nothing to be consurned about.   MACK
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 6:09am
One of our 7060s has that rattle too, normally it is only present at idle RPMs, if you bump up the RPMs just a couple hundred does it go away?  If so, run her hard, and don't worry about it as MACK said.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 7:59am
Thanks for the information.  Also, another thing I just thought about, the A/C is supposed to work on it but when we turned it on and drove it down the road it seemed to be blowing somewhat warm air.  The guy said that it has a temperature sensor that doesn't allow it to come on unless the outside temp is a certain temperature, which I have never heard of that before.  The temperature outside was probably only 45-50 degrees though.  Would we be able to tell if the A/C is working with the outside temp at 45-50 degrees?  The compressor seemed to be on when we turned it on.
Thanks
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 8:07am
Don't think you'll be able to check the AC at all unless outside temp is at least near 70 or above.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 11:14am
It could be the heater valve leaking some too when it is shut off, so you have some warm coolant passing through the heater core.  Most people tend to put a ball valve at the water pump to manually cut off the heat in the summer.
Hurst
1979 Allis Chalmers 7000
5800 Hours
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 1:32pm
I would agree w what orange blood said , our 7040 did the same thing .
I sure  wouldnt be scared of that 7060 , cheap hp for low dollars
 ya , i know .....the cab sucks , but it is quiet ...
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 2:37pm
Thanks
if the compressor clutch is engaged, driving the compressor, then that eliminates any switches. The pressure switches simply will not kick the clutch for compressor in if pressure too high. Sounds like it leaked the refrigerant out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 6:59am
I tend to think that if the A/C were working properly, then it should cool even at those temps, but I am pretty sure the 7060s we have, all have low pressure cut outs on them, can't be positive, but when ours leaks down the compressor won't engage.  Anyway, the heater valves in the cab, are not very good at shutting off coolant after all these years, so what typically happens, is the heater kills everything the A/C is trying to accomplish.   So it is a toss up, worst case as Ed pointed out, you probably just need a charge, and find the leak, best case, you need a vice grip to pinch off the coolant hose, or install a new valve in the top of the cab.
All in all, it will probably serve you well.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 7:50am
Thanks for all the info guys.
This conversation with the A/C has been interesting.  We just put all new parts with 134 air in our 200 and and it sure isn't as cold as it should be, especially if you are working the tractor.  It sounds like the 200 would have the same problem, with a bad valve that is not shutting off the heat.  I assume a ball valve would help us out here too.  So a good way to test it would be to put a vise grip on the coolant hose that runs to the cab and see what happens with the A/C when the engine is good and warm?   Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:37am
A Ball valve installed in the right spot would be the ticket, the vice grip is really a temp diagnostic aid, be careful not to pinch too tight, the hose could be damaged.  I don't know the numbers, but 134a should cool, I think 35+ degrees below ambient temp at the condenser, so a couple of things can affect this, clogged or dirty condenser, low air flow, heat drawn in from another source, i.e shrouding missing, the other thing I have really noticed with 134 is a clean system, I am a firm believer in a quality system flush of all parts, when I put in new system components, I flush everything except the compressor and the dryer, of course those are typically what I am replacing, but my chevy truck, a '95, which was early in the 134a era, will cool to 40ish degrees on most 80+ days, and down to 55-60 on most 95-100 degree days.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 8:03am
We just put a brand new fan motor in the cab so we should have plenty of air movement.  All the lines were cleaned out when we put the new compressor on.  The fan motors on the condensor on the back of the cab were not replaced and sound weak to me, we talked about replacing them, but haven't done it yet.  I might try the A/C this weekend with the vise grip diagnotic and see what happens.  I bet that is it.  Our M2 has a valve that we shut off in the summer too, not sure why I didn't think about that before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 8:13am
Not sure what you mean by fan motors on the condenser on the back of the cab????
On the 7060 the condenser is in front of the engine radiator, and the engine fan pulls the air.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 8:33am
Oh sorry, I was talking about our 200.
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 10:13am
A 7060 is a very good tractor, lots of power, 2 ptos, at 4000 it should have lots of life left. Charge the air with some off the shelf stuff, good to go, Trev.
