Harrogator Information Needed
D17Four View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17Four Quote  Post ReplyReply Direct Link To This Post Topic: Harrogator Information Needed
    Posted: 17 Mar 2012 at 10:24am
How high off the ground will a Dunham Lehr harrogator lift?  Can I pull a 16 footer (12 feet without the wings) with a Series IV D17?  I am considering buying a harrogator to help flatten a field torn up by removing a lot of trees and brush, with a lot crap left behind.  My plan is to pull the implement until it loads up, lift it to "dump" the load then move on.  I will come back later to "sift" the pile with a Bobcat/rootrake, then repeat the process many times.  I don"t think my plan will even begin to work unless I can get that harrogator at least a foot, and preferably 18" off the ground.  Any thoughts or adjustment information on this implement is most appreciated.  Thanks.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 10:59am
Should pull 16' easy,don't think it will lift that high.
This page was generated in 0.049 seconds.
