ED40 Brakes
joegrgraham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Topic: ED40 Brakes
    Posted: 26 Nov 2011 at 9:08am
Hi all, now I know ED40's aren't all that common in the US, but I know there are a few, and I know a few UK guys read this forum, so I'm hoping someone can help.
I need to reline the brake shoes on my 1965 Depth-o-matic, and the pin through the bottom of the final drive casting which the shoes are attached/hinged on refuses to move, I've removed the grub screw, all the linkage and adjusters are removed and the shoes themselves are moving freely.
I've soaked in penetrating fluid, I've heated them, I've beaten them, I've swung on them and still the damn things will not budge an inch!
So, my questions are, has anyone else done this job and how did they do it? have I missed something? or do I just need to resort to drastic measures and cut the things out?
If it seems like a good idea, do it. It's easier to apologise than to get permission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 12:48pm
Tried again and still nothing, looks like I'll have to cut them out.
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 2:44pm
try the UK allis owners club
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 2:48pm
Do you know anyone who has an impact driver?  Perhaps you can attach a hard dowel to the chuck and drive them out that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 3:05pm
trouble is, the inner end of the pin is inside the casting, no way to get behind it to drive it out, looks like they should just pull out, but they just rusted in solid.
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 5:09pm
I’m not familiar with the ED40 but I think I would try to weld a nut to it before cutting it out. I would use a nut that was as big as I could get but still smaller than the pin diameter to the pin by welding the inside (threaded part) of the nut. Then you can put a wrench on it to wiggle it back and forth to break it loose. I’ve used this many times to remove broken of bolts and studs. I’ve had better luck using a stick welder over a mig. I’ve also sometimes use a washer that is slightly smaller than the nut size to keep from welding to the side of the housing.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 12:23pm
Many Thanks for the link DougS, those WD brakes are as near as makes no difference the same as the ED40, so I shall try that method.
Stray: already tried that! :) nuts broke off and took half the visible part of the pin with them!
Thanks for the info guys.
This page was generated in 0.053 seconds.
