hard PS 8010
jjpetrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Topic: hard PS 8010
    Posted: 19 Mar 2012 at 10:15pm
Compared to our 8050 the 8010 power shift is harder to move from each gear to the next.  Just wondering if its a fluid problem since i dont think the cable is wore out.  Any advise would help.
On the farm wd,wd45,180,200,7020,8010,8050,f,L2,2 b engines
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 10:25pm
It would either be the cable or someone has been inside the shift control behind the batteries and rounded the saw teeth on the 8050 to make the action easier.
The innovators offer what others will imitate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 6:30am
Replace the cable.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 7:57am
Through the years of PS there were at least 4 different spring and linkage arangements for the detent. One had 3 different holes for spring for how much detent pressure you wanted. You could have this one set for most detent pressure. MACK
