Name this Allis and components ? |
Macon Rounds ![]() Orange Level ![]() ![]() Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2229 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Mar 2012 at 3:26pm |
![]() Name the tractor,
Name the hoe?
Name the loader?
BLee Mn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Montevideo Mn Points: 680 |
i'd say it looks like a D-19D tractor, but after that no clue
Cowboy UP
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
D-17 Series III industrial diesel with a TS-1000 loader and a Mark IV hoe.
The loader and hoe are Henry products. Edited by Calvin Schmidt - 21 Mar 2012 at 3:47pm |
Dave (Mid-MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Hemlock, MI Points: 566 |
Tractor appears to be industrial D-17 with shuttle. Don't know about hoe or loader.
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29805 |
Bill, Frank and Joe. Anything else you need named? ;')
Wink I am a Russian Bot |
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9654 |
Lonn ya beat me to it.LOL
The tractor - Betsy The hoe - Doug the loader - Hoss
Very Good Fellas !
Yes it is a industrial D17 series III diesel with shuttle shift. 1963 S/N 70546D
The hoe is a Henry Mark-IV s/n 3A1518AC
The Loader is a Henry TS1000 S/N 33I3AC
It's fun to see all the responces.
Anyone know of or have one set up like this?
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
I've never seen one other than pictures but I'd sure like to own one.
AGCO My Allis Gleaner Company
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Calvin has it all the way!
OK, I cheated a little. Had to check a brochure to see if it was a TS -1000 or L-200 loader. It is a very rare comb and I've never seen one for real. I've never understood why A-C built the I-60/600/615 on the D-15 tractor instead of the D-17.
cmsmoke ![]() Bronze Level ![]() Joined: 19 Feb 2011 Location: Johnstown, Pa Points: 118 |
I don't see a "ho" on that tractor...OOPS!
Looks like a good start.
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41980 |
The hoe is real similar to the AC 615 detachable hoe I have that came off a HD4 loader. Same type cesna swing rotary piston, but the legs are mounted a little higher on frame. This unit is 4 stick where my 615 is 2 stick for hoe controls.
TomMN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elbow Lake, MN Points: 858 |
My D17 Industrial is a gas but was probably set up just like that. It still had the TS1000 loader but the hoe had been removed with a cutting torch. Here is a link to some pictures of mine - It is now disassembled and only the loader is outside otherwise not much in the line of progress.
http://home.comcast.net/~old_allis/ac-D17.html |
Yea Calvin you hit it right on the nose. Good Job.
Coke, I believe the reason Allis didn't make the D17 the power plant for their Back Hoe and loader combo was three fold. It is a powerful beast. Over 11,000 Lbs without loaded tires or ballist, The turning radius is not condusive for tight quaters. And the power steering is slugish as it has the same power assist system like the farm tractors. The i600 and an i40 will both run circles around and inside this old D17 because of the shorter lenght between drive and streering axels and the true power steering they have. The good thing about this old D17 is it runs better than any of the other Budas i have and the hoe has litttle or no wear. Yee Haw ! Tom, i saw your D17 industrial when you first posted the photos, although it was in bad condition i was jelious. Now i found this beauty and my wife is calling it my Girlfriend. Ha ha!!! SHe is a beauty. How is you D17 industrial project comming along? |
I wish I had some progress going on mine but at least the major pieces are inside out of the elements. The engine in mine looked good from the outside, but when I took it apart I found it split at the bottom of all the sleeve webbing. The center web was split through to the main bearing, so the block in mine was scrap. I have a replacement block that I think is OK but I haven't done much more than take it apart and verify that the bottom isn't split out.
How does the shuttle shift feel. Does it lock up good in forward and reverse ?
The shuttle seemed to be pretty good, I have that shimmed up and ready for whenever I get around to putting some time into the tractor.
