D17 Hood question
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Hood question
    Posted: 09 Jun 2012 at 4:53am
Did Allis put a rubber edge around the exhaust or Air Intake holes on the hood? I am thinking about adding something to keep from scuffing the intake pipe up when removing the hood.
Also at the exhaust hole, there are 3 small holes equally spaced around the hole, what was that for?
Charlie
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 5:49am
No rubber edges on the D series hoods.  Three small holes have been added later in the tractors life
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 6:23am
Interesting about the holes, they are so symmetrically spaced that is looks factory.
Charlie
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 8:26am
If a tractor had a cornpicker mounted on it, those holes may be for a thrash deflector around the muffler
DEP5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DEP5 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 8:35am
s
These may be for the block-off plate, the under-hood muffler option.
D10 Series III, fully optioned
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 12:16pm
it did have a picker on it most of it's life I am told.
Charlie
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 1:21pm
If you could locate a plastic or cardboard tube of the correct diameter, you could simply slip it over the air cleaner pipe each time you removed or installed the hood.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 2:42pm
The holes are for a muffler guard for picking. I got a round one and a rectangular one (for oval mufflers) with my 170 picker.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 9:28pm
Good idea. I have been using painters tape
Charlie
