gleaner tresher door removal
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: gleaner tresher door removal
    Posted: 05 Jun 2012 at 10:53am
on an l series- looks like a long rod- hard to get out? just drop the pin and bang it out? anybody ever done this?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 12:35pm
They are usually a bitch to remove.The rod is either stuck(rusted) to the door or where it goes thru the throat.Make sure that you remove the wire that operates the rock door light ,and then drive the rod out with a smaller diameter rod or shaft.Try not to mushroom the end of the rod and use plenty of penetrating oil.It might help to drive it out one way a bit and then go back the opposite way.Be careful,that door is heavy.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 8:06pm
I had a similar problem with an L3,  Finally left it and went on combining it was seized so bad...about three year later some one picked up a stone.  Broke the door right off, made it much easier to heat up the hinge and get the rod out...it is heavy.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 8:31pm
Time goes by and I forget, but on our 81 N6 if I remember right, there was a roll pin in the middle of the hex shaft that you turned the door up with.  Ours seemed like it came out easy once the roll pin was removed, the shaft pullled right out, and the door came out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 12:19am
worst case ....get the sazzall. trim off inside by door edge. then you heat and beat it out. door on an F is heavy....can't imagine what yours weighs....good luck and be CAREFULL !!
This page was generated in 0.046 seconds.
