Help - Gas Tank Trouble
houchens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote houchens Quote  Post ReplyReply Direct Link To This Post Topic: Help - Gas Tank Trouble
    Posted: 23 Apr 2012 at 12:09am
The gas tank for my Gleaner K got all gummed up and rusted, which clogged the fuel line, settling bulb, etc. Fortunately it didn't get to the fuel pump or carb. This led us to running it off an aux. tank for awhile, but finally decided it was time to get this issue solved.
Got the tank taken off, and the line and bulb unclogged and in good shape. Wondering what the best, most economical way to get the gunk out of the tank would be.
Thanks
8050 200 7010 185x2 D17-IV D15IIx2 D14 WD45 Deutz Allis 6260 Gleaner Kx2 Gleaner K2 Diesel 2300 discx2 600 and 333 planters 2 AC wagons several AC plows/chisels Rotobalerx2 Other Misc AC Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 6:16am
If you have a local Radiator shop, quite a few radiator shops offer fuel tank repairs also. Might wanna give your local Radiator man a try and see. Then you don't have to mess around with acetone's and etchings or whatever to clean the tank out... HTH
BoBMeL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BoBMeL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 7:29am
Hi I'm Bob I had a similar problem on my d12 something that can be done at home is pour a cup of practice gravel in the tank and shake it around it worked for me so I'd try that
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 9:52am
My D10 tank was so bad, gravel, chains, MEK, Acetone etc did not work.
I cut a large section of the bottom of the tank out, had the inside sand blasted, then I welded the piece back in place. Then coated the inside.
Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 12:05pm
Now THAT'S cleaning out a tank Bill!!  LOL  Big smile
